06-21-2017, 01:44 PM | #1 |
518
Rep 582
Track Pad knock - PFC08
I'm running PFC08s on all four corners and have had no issues thus far on track - good initial bight and excellent modulation. Other than lots of break dust and squeal, these have been great.
My question is: Is it normal to hear/feel the pads knock into place whenever changing direction from forward to reverse? For instance, they knock into place whenever I apply the brakes after having just previously reversed the car and knock into place while reversing and applying brakes after having gone forward previously. I assume this is normal and a non-issue but just wanted to check the collective wisdom here. A buddy running these pads on an E92 M3 noticed the sound and said that he doesn't get the same phenomenon - although I understand his car has a different caliper design. Thanks. Last edited by dvas; 06-21-2017 at 02:15 PM.. |
06-21-2017, 01:54 PM | #2 |
538
Rep 624
I run Pagid RS29 and have the same problem. I first thought it was a mistake on Pagids part that they got the backing plate dimensions wrong. But it's the same on both front and rear pads. And I read somewhere that they are made slightly to small to prevent getting stuck when expanding due to heat.
PS: Do you mean you are running PFC08? Or FCP?? PPS: I get really strange looks from people on the street when the car does this loud knocking sound Last edited by MagnusT; 06-21-2017 at 01:59 PM.. |
dvas518.00 |
06-21-2017, 02:15 PM | #3 | |
518
Rep 582
I get a lot of looks too on the street. People always seem to be looking for a 16 wheeler. |
06-21-2017, 06:08 PM | #5 |
75
Rep 61
I'm running PFC 08s as well and they do the exact same thing and it is totally normal.
One thing to note is that they got much quieter past my first track day. Still squealing a bit once in a while but absolutely acceptable for daily driving. |
dvas518.00 |
06-23-2017, 08:52 PM | #6 |
47
Rep 112
I have the 08s mine do it. Just use them at track. I will look when I take them out to see if there is any damage to the sides of the pads from knocking.....
2017 BMW M2 PE MT
2006 Z06 2004 Miata |
06-23-2017, 09:41 PM | #7 | |
634
Rep 650
06-24-2017, 01:19 AM | #8 | |
230
Rep 254
to the OP, mine knocked as well. also the squeal was god awful on the street. they only lasted a day after my track day before i had to take them off. |
