Staggered 19" VZ15 on E90 AWD?
05-05-2008, 12:03 PM | #1 |
Rep 164
I'm looking ar purchasing a set of Hypersilver 19" Velocity VZ15 with a staggered setup on my 2007 E90 328xi. I just wanted to make sure the following setup will run fine with no issues, especially rubbing.
Front: 19x8.5 et 38 ( 235/35/19 tires) Rear: 19x9.5 et 30 ( 265/30/19 tires) If I dont do this setup I was thinking of going with the same wheels with 19x8.5 all around with a et 40 and 235/35/19. Would this be a better setup with the 40 offset? Also, do the stock wheel bolts work on these wheels or do new ones need to be purchased? Any information would be helpful! |
05-05-2008, 12:14 PM | #2 |
375
Rep 17,017
Both setups would work perfectly on your car. I would personally go with the staggered rears as they will sit better inside the fender than the non staggered setup. If you do non staggered, run a set of 8mm spacers in the rear to push it out a bit more.
The stock lug nuts will transfer right over to these new wheels as well. |
05-05-2008, 01:09 PM | #3 |
100
Rep 2,528
Drives: 95 Avus M3 and 07 E90 Fam Car!
Go with the 8.5/9.5 staggered set up, you will love it and it will work fine on your ride. You will regret going 8.5 all around. Unless tire and wheel rotation is absolutely necessary.
