M2 Technical Topics > Track / Autocross / Dragstrip > Camber Plates
      06-13-2017, 01:19 PM   #1
Nomad0001
Drives: Corvette
Camber Plates
Noob on these.
If you have these installed and marked with your street and track settings, can you just change them when you get to the track and put them back when the track day is over?
I saw a video (different make of car but similar set-up). I seems like he just jacked up the car with a floor jack, loosened the set screws, moved the top of the strut back and forth, and tightened them where he wanted the camber to be.
Once you have it all marked, is it really that easy?
Thanks,
MD
      06-13-2017, 02:52 PM   #2
tux2005
234
Drives: 2017 M2
I'm sure other more knowledgeable people will chime in but my understanding is that while adjusting the camber value is as easy as you describe the issue is it also affects the toe-in which you cannot easily adjust.
So if you have a high negative camber for track use and the toe-in is set as desired then if you adjust the camber for street use then the toe-in will be thrown off for street use. Because of this I think it's common to set a compromise camber and toe-in and not adjust the camber frequently.
      06-16-2017, 01:36 PM   #3
TimOudin
15
Drives: 2017 BMW M2
I won't claim to be more knowledgeable, far from it, but this description is consistent with experiences. My mechanic did an alignment for me in the past to attempt to have both street and track setups, marking both the camber plates and whatever it is that used to adjust toe. The impact to toe with a small change in camber was pretty significant, though this was not my M2 so YMMV. It proved to be such a hassle that I just ran -2.5 camber all year round and had absolutely no significant issue with excessive tire wear.
      06-17-2017, 03:21 PM   #4
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
You can but your toe might still be a little off even if you mark it. I run -2.75 all the time with very minimal toe out in the front.
      06-19-2017, 08:00 AM   #5
Wangspeed
51
Drives: BMW M2
You'll pretty much ruin toe settings if you adjust the camber. I have mine set to -2.5 and 0 toe and just call it a day.
      06-22-2017, 08:40 AM   #6
dvas
dvas's Avatar
518
Drives: 2017 M2 - Mineral Gray, 6spd
What kind of tire wear have you been experiencing on track with this setting?
Also, what settings are you guys running in the rear?
Thanks, looking to get camber plates shortly to save front tire wear.
      06-22-2017, 05:00 PM   #7
The HACK
The HACK's Avatar
1820
Increasing static camber increases toe-out on a MacPherson based strut. Toe-out has beneficial effect on track and autocross (quicker turn-in and steering response). Having a street camber (say, -1.2º) with a mild toe-in (1/16" total) may result in a zero or mild toe-out when increased to -2.5º camber for track use, which is beneficial.
The problem lies in how MOST camber plates are adjusted. For example, this is a KW camber plate on an E9X M3:
See how once the strut is installed, you can't really access the two inner bolts to loosen the camber plate? Here's an example of Ground Control camber plates:
This appears to accommodate a more significant increase in negative camber before you run out of room to tighten the bolts. But let's say the "zero" position it's aligned to right now is "stock" camber, to get to -1.5º you would have to adjust the plate 1 click in, and to get to 2.5 you would have to adjust up to 3 clicks in. On this particular plate, the two inner bolts may be too far in to be tightened underneath the strut brace.
so while in theory you CAN set the camber for a street and a track setting, in practice it depends on the camber plate you use. A "better" way to adjust would be to fix the camber plate at a certain position with the top of the strut pushed all the way out to the far outer edge (say, the camber plate set to the -2º position) for a total of -1.5º of camber for street, then for track you loosen the top strut nuts and push the assembly in to the max setting to gain ~-0.7º of negative camber for a total of -2.2º rather than trying to adjust the plate itself.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
      06-23-2017, 07:02 AM   #8
Wangspeed
51
Drives: BMW M2
My track tires, RE71r square setup, look pretty good with -2.5 up front. The rears are stockish. I can't remember, but I think that was -1.9 or -1.6.
dvas518.00
      06-23-2017, 12:32 PM   #9
rjn
43
Drives: 2017 M2
Those other two holes (closer together, on the silver plate on the far side of the rod) are where you move the fasteners that would slip under the tower for more aggressive camber settings. The GC plates give plenty of adjustment.
The trick is getting to an predictable/acceptable, and repeatable toe setting at the end you don't optimize for. That's why some of us leave it be. I'm at -2.75/0
      06-23-2017, 01:28 PM   #10
The HACK
The HACK's Avatar
1820
No. You don't understand how camber plates work.
Camber plates increase negative camber by moving the TOP of the entire strut assembly one way or another in relation to the strut tower mount. You can't possibly just loosen those two bolts and move the camber assembly. The 4 "yellow" or brass colored bolts all need to be loosened to allow the grey plate underneath the red to slide in and out in relation to the red plat (which is bolted to the tower) to increase and decrease camber. You can see it more clearly on this image:
And as far as consistent toe gains, the amount of toe gain is relative to the amount of camber gain. So if you aligned the car to have, say, 1/16th total toe in at -1.5º camber, then your shop moved the camber up to -2.5º and it became 1/16th toe-out, every time you move it back to -1.5º your toe will be 1/16th in, and at -2.5º it will be 1/16th out. There's no "guessing" game there as long as your shop aligned it right. That's why the "trick" to align for a small amount of toe-in with street camber works, since your track camber (more negative camber) will result in toe-out, which is conducive to track driving.
      06-24-2017, 06:44 AM   #11
Wangspeed
51
Drives: BMW M2
The toe change as a result of camber change is far more than what you wrote. It's quite high. To the point where I decided it would be almost impossible to accurately set toe. Which, quite frankly, will have a larger effect than a few tenths of camber.
      06-24-2017, 04:08 PM   #12
rjn
43
Drives: 2017 M2
Really? Thanks for that professor. Since I've already installed them on mine, I kinda understand.
See the other two holes in the silver plate with the "GC" cut out in the photo you just posted? That's where 2 of the 4 fasteners go if you want enable a more aggressive camber setting. That way the leading 2 fasteners in your pic are no longer in the way of further adjustment. That's where mine are to get -2.75. The plates come with a spacer for them that goes under the silver plate if you need to use them. You obviously tighten all four, in whatever position you select
But I'm sure you know all that already.
Yikes
Appreciate 2
rwalker329.50
      06-25-2017, 08:57 PM   #13
3Si
3Si's Avatar
217
Drives: 16 M2, 16 Macan S, 08 Elise SC
Another noob question... Do they come in sets of 4 or 2?
      06-25-2017, 10:36 PM   #14
greasypeanut
230
Drives: F87
comes as set for the front (2)
3Si216.50
      06-26-2017, 04:53 PM   #15
rwalker
330
Drives: the wheels off
rjn is correct, GC has 2 options for securing the slider
rwalker@rwalker.com (I really dislike Private Messaging)
      06-26-2017, 05:27 PM   #16
tstafford
tstafford's Avatar
30
Drives: 2017 M2
How much negative camber can you put in to the car w/o plates?
      06-26-2017, 05:40 PM   #17
rwalker
330
zero
      06-27-2017, 06:18 AM   #18
tstafford
tstafford's Avatar
30
Drives: 2017 M2
Originally Posted by rwalker View Post
zero
Oh. Well I guess I need some camber plates.
      06-27-2017, 10:39 AM   #19
DelGriffith
DelGriffith's Avatar
325
Drives: 2019 SO M2C
Yikes
Crickets....
'02 E39 M5-Gone
'07 E60 M5-Gone
'07 E64 M6 Cab-Gone
'17 F87 MG M2-Gone
'19 F87 SO M2C
rjn42.50
      06-27-2017, 11:17 AM   #20
tstafford
tstafford's Avatar
30
Drives: 2017 M2
While I understand that adding rear control arms would be best, are you guys getting at least a decent track alignment on the car with just front camber plates? Or is it necessary to do both at the same time?
Thanks in advance.
      06-29-2017, 10:33 AM   #21
CosmosMpower
2051
Thanks in advance.
I got -2.75, I wanted -3 but I couldn't get the toe in spec with the camber above -2.75.
      06-29-2017, 05:41 PM   #22
tstafford
tstafford's Avatar
30
Drives: 2017 M2
^^^ Thanks.
I ended up ordering GC front camber plates and two sets of Fall Line toe links so that we can replace both the toe and trailing arms. Hoping after this (and the alignment) that I can eliminate some of the tail action I'm getting.
m2
