HELP! How do I get chewing gum off the paint?
05-04-2008, 01:38 AM | #1 |
42
Rep 295
Well, this morning I noticed that some chewing gum has been kicked up by the tire onto the bottom part of the tire well. Basically it has gotten stuck to the paint.
I have tried to remove it the best I could but some of the residue is still stuck on the paint (pics will follow). Can anyone suggest a method to remove this chewing gum from the paint? |
05-04-2008, 06:10 AM | #4 |
Perfection Is In The Details
67
Rep 1,044
The big question is if it is "sugar less" or not. Sugar less gum comes off quite easy and regular gum is a bitch.
You always want to start off with the least aggressive way as possible. TRY: 1. Strong soap and water with light scrubbing 2. Clay 3. A degreaser like simple green "diluted" 4. Vinegar and water diluted 5. Goo Gone
2006 E90 SG-Dinan Ram Air Intake-Dinan Throttle Body-Dinan Exhaust-19' Hyperblack CSL's-15/5 tint-Matte Black Grills-M3 Spoiler Lip-Amber Delete-Smoke Side Signals |
05-04-2008, 07:02 AM | #5 |
30
Rep 1,381
I agree with LRG, go with the least aggressive first, however, I will say that I've used Goo Gone on paint before with absolutely no ill effects. Just be sure to clean the area very well after you use it.
2008 BMW 335i: Jet Black, Jade Gray, Gray Poplar, 6MT - Stock... for now.
05-04-2008, 10:15 AM | #7 |
Special Forces - Discretion is superior
31
Rep 1,011
Drives: 335i Coupe Sapphire Black
I wouldn't recommend gasoline.
Like AJerman and the others above, I've used Goo Gone extensively on many different parts of vehicles with no issues. However, make sure you thoroughly wash off the area when you're done and then reseal or wax if painted. However if that product (Goo Gone) is not available where you are a basic mild solvent based degreaser and some cotton swabs or similar applicator might work fine. If it's a single spot or only a few blobs you might try to freeze it until it becomes brittle and then with a gentle nudge or pop with a plastic credit card or something similar it might just knock right off. I also like L~R~G's proposals too.
M3 + trailer hitch = oxymoron
05-05-2008, 12:19 AM | #9 |
Rep 26
Drives: 2008 E93 335i
Bug and Tar Remover works too. i happened to just help out a friend of mine by getting about a square inch of solid dried gum off her Acura MDX with the bug and tar. it took a little bit of elbow grease but it worked just fine and didn't harm the paint one bit.
05-08-2008, 10:43 AM | #11 |
42
Rep 295
update:
Went to a store called Yellow Hat (apparently a Japanese store - specialising in all car related stuff expecially ricers - they had a lot of those light kits there) and the guys there recommended some Pitch Remover. Sprayed it onto the gum and 2 wipes the gum was gone. Got the car washed right after and the paint looks as good as new. Awesome. Would highly recommend Pitch Remover. |
05-08-2008, 10:56 AM | #12 |
142
Rep 3,523
The pitch remover prob. removed the wax, better to re-seal the area.
I think the "pitch" term is the same as "tar" meaning it has solvents that pull off your wax/sealant. |
05-08-2008, 11:18 AM | #13 |
148
Rep 2,932
You should've washed the car before doing it, but good to hear it came off. Just remember that wiping anything on the paint when the car is dirty will cause marring.
05-13-2008, 09:33 AM | #14 |
42
Rep 295
Thanks for the tip on re-sealing the area. I got it done yesterday.
And thanks 328i for bringing up the washing. I did wash the car before I applied the pitch remover. I just decided to wash it one more time after as well (got the interior cleaned as well this time). |
