05-29-2017, 10:47 PM | #1 |
Rep 9
Strange CEL code
I was driving a long distance today and I got a CEL, when I checked the code to see what it was, the code given was P147E. I cleared the code, but it came back the next time I started the car up. It is running fine and doesn't seem to be having any issues. I tried searching around for this code definition and couldn't find anything.
Any help would be appreciated. the car is a '13 328i (F30) thanks, |
05-30-2017, 07:05 AM | #3 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
There is a recall out for the in-tank fuel pump, and a google search indicated that code is related to that very component. Check with your dealership - having them do the recall work won't cost you anything. Although I didn't have any codes, I had this done to my '13 335i recently at no charge.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
03-05-2018, 06:33 PM | #4 |
Rep 1
Hi ....actually i was looking 4 same problem code p147e...tank leakage module short to ground...fixed...just go to ur rear left tire and inspect the wire harness ...is internal cut I found it today on customer car
06-05-2018, 04:29 PM | #5 | |
Rep 1
Hi, I just ran into this issue after switching upper and lower fuel pumps. Seems like as soon as I fix one thing, literally right after something else gos. What wire exactly am I looking at? |
