Electrical System Gone Crazy
05-28-2017, 09:22 AM | #2 |
1903
Rep 6,968
I think your battery or alternator is going bad. Probably your battery. Bad batteries will make the car go haywire.
05-28-2017, 09:46 AM | #3 | |
Apprentice
373
Rep 801
I'm not completely ruling out the battery. But it does seem strange that your putting out rather high voltage. |
05-28-2017, 09:59 AM | #4 |
Save The Manuals!
64
Rep 491
2008 E91 36K, 6-speed, RWD, Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Euro split armrest, Lidatek, remote V-1, Cocomats, beach sand, $10 clutch stop mod. 1998 Volvo V70T5 226K, 5-speed, original clutch (third clutch pedal!), aspheric driver's mirror, E-code headlights, IPD sway bar, strut tower brace & skidplate.
05-28-2017, 10:04 AM | #5 | |
225
Rep 807
Drives: 2011 335is 6MT
OP are you clearing the codes? can you take a pic of the top of the battery so we can help you confirm the IBS is there? I think you have an alternator issue. |
05-28-2017, 10:16 AM | #6 |
22
Rep 73
As an electrical engineer, I can say that if you're measuring one voltage at the alternator, and a different voltage at the battery, there MUST be some resistance between the two points... simple Ohm's law.
That said, the voltage drop across the cable (between the alternator and the battery) will be directly proportional to the current flowing through it. (Again, Ohm's law.) Since no wire can be completely free of resistance, the reading at the alternator output MUST always be higher... and while it's charging the battery there MUST be some current flowing, so there has to be a higher voltage at the alternator (always), it's just a question of how much higher is 'normal'. (And -by inference- how much resistance and current flow is 'normal'.) Has anybody ever measured THEIR alternator output, to see what it's putting out under the same conditions? |
05-28-2017, 01:19 PM | #10 |
1911
Rep 13,104
Try putting a slow full charge on the battery see if things change.
Also measuring the resting voltage of the battery in the morning before first start should tell you something about it's health. |
BimmerGeeks1180.00 |
05-31-2017, 12:28 PM | #13 |
22
Rep 63
closed
Bimmer 808170.00 lab_rat394.50 |
Tags |
320d electrical, 4a56 |
