ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      05-02-2008, 01:01 PM   #1
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Considering e92 M3 18's
I am thinking about putting 18" e92 M3 wheels on my car. Seems a bit aggressive at first glance, but not really compared to some setups I've seen with 10-15mm spacers. I am pretty sure the offsets I have input are all correct, if not please let me know.
      05-02-2008, 01:40 PM   #2
mPlasticDesign
684
e92 M3 18' on Mcoupe
I am a big fan of the new M3 18's. I am pretty sure they would look good, just don't know if they would work. Here is a quick photochop.
      05-02-2008, 02:55 PM   #3
dekaliber
74
Drives: '07 Z4MC, '11 JCW, '18 Z06
I do think that would look hot...with 19mm extra in the front though, isn't that almost guaranteed to rub?
      05-02-2008, 03:21 PM   #4
mPlasticDesign
684
I dunno? that is about 3/4" out, but at stock hieght might be ok? I was hoping to get more feedback.
      05-10-2008, 06:20 PM   #5
AWM3
BMW Fan
AWM3's Avatar
11
Drives: 2012 E92 M3, Alpine White
The car's handling is a bit tricky at the limit already. Messing with the offsets like that may worsen that problem. It will look odd with the front wheels pushed all the way out to the very edge of the fender, or beyond.
There are plenty of great wheel choices for your car, why use something that will never be right even if you can manage to squeeze it on.
      05-21-2008, 06:38 PM   #6
Irish Bimmer
Drives: M Coupe
I would love to see someone try this - I think it is doable but is extremely aggresive... throwing in some negative camber should help, as well as going with a 235 up front.
      05-21-2008, 09:23 PM   #7
Dieselino
Dieselino's Avatar
47
Drives: 03 LSB M3 06 M coupe 08 M3 SG
I get rubbing with a 8.5inch wheel with 225's and 35mm offset. This will definately cause rubbing in the front when the wheel is turned full lock. Plus I think it will stick out too far, might start to look ghetto.
      05-21-2008, 09:53 PM   #8
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
167
Drives: 2007 M Coupe
I think as far as the cars handling near the limit is concerned...it's not that tricky...just keep the gas near the floor and she'll be have like you'd expect
I like the new M3 19s better...
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      05-21-2008, 10:28 PM   #9
MMMazing07
More than you can afford pal....ferrari
MMMazing07's Avatar
180
Drives: Z4M
why not some e46 18s? they look very similar and would fit perfect.
i would never run more than a 10 mm spacer IMO.
      05-22-2008, 05:55 AM   #10
Irish Bimmer
Drives: M Coupe
This setup would definitely not require the use of spacers - spacers would make the problem even worse.
I know that there are some reps of the M3 19's that might work...
The biggest issue of making understeer even worse would be that to even stand a chance at getting this to work you'd need 225's and would still want to have 275's in the rear. That big of a difference betweeen front and rear would make the car even more unstable at the limit.......
      05-23-2008, 10:29 AM   #11
Reach
gone baby gone
381
Drives: 2016 F80
Yah. The rears would fit a treat, but the fronts are NOT going to work for you, sorry to say. Spacers wouldn't help, they'd only make it worse.
      05-23-2008, 11:03 AM   #12
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
167
I'm sure if you don't mind waiting...someone will make some reps that would fit.
Best Website EVER!
      05-23-2008, 12:05 PM   #13
mPlasticDesign
684
Yeh, I don't think it's worth the trouble. I will wait.....
I never suggested putting spacer on this setup. I was merely comparing a 15mm spacer setup up front to the built +19mm offset these rims would have on our cars. And I have been reassured the 19 reps work fine on our cars. I just happen to prefer the look of the 18's.
      05-23-2008, 04:11 PM   #14
Irish Bimmer
Drives: M Coupe
I never suggested that you suggested putting spacers on this setup. The post directly above mine a few posts up stated that they'd never use more than a 10mm spacer - even still I wasn't posting directly in response to that. I've seen numerous posts throughout the wheel and tire forums that lead me to believe that some people think spacers INCREASE the offset when they actually DECREASE it. I'm not posting this to you, as I'm certain you understand this; however, I think some people can benefit from this info.
      05-23-2008, 04:13 PM   #15
mPlasticDesign
684
It's all good, I don't get upset that easily!
      07-24-2008, 01:22 AM   #16
type7
Drives: 07 M Coupe
I am glad I found this post. I almost bought those.......... Thanks guys.......
      07-24-2008, 09:57 AM   #17
clubspec330i
71
Drives: MG F39, CB F86, MB 911T
OEM E90/92 18" tires would DECREASE understeer of M Coupe. 245/265 PS2 would be much better match than 225/255 PS. However, understeer is not entirely a bad thing. You want it just a tad bit...because it is easier to correct than oversteer.
Keep us post on what wheel you end up getting...
      07-24-2008, 10:23 AM   #18
mPlasticDesign
684
I just tried to buy a set and was second in line to buy them, but they were SOLD fast. I am will to try this setup, just need to find a used set.
      07-24-2008, 11:18 AM   #19
Tallest
Tallest's Avatar
1282
Drives: 911
2011 911  [10.00]
it will look absolutely hot. I hope it wil work out...
997.2
F30.F11.E86.E90.E90.E36
      07-24-2008, 12:05 PM   #20
rlc
rlc's Avatar
33
Drives: '06 E90 - '04 E85 - '16 F15d
2016 BMW X5 35d  [0.00]
2006 330i  [0.00]
2004 Z4 2.5i Roadster  [9.00]
I'm not sure what the difference is for the overall diameter for what you are consdidering, but based on your posted offsets you are moving the outer edge of the tire on both the front and rears less than one inch.
I put E92 18" rims/tires on my Z4 and moved both tires out by one inch with no problems with rubbing. Now, I know there are differences between ///M and non ///M cars but it seems like you should have no problem with the fit. As others have mentioned you may alter the handling characteristics, but after I changed mine the car drove BETTER and tire wear after 5000 miles appears normal.
Good luck, I think it will look great.
http://www.zpost.com/forums/showthread.php?t=94295
      07-24-2008, 12:40 PM   #21
mPlasticDesign
684
Yes I remember your thread. That setup looks so much better now, while retaing the "stock" look.
      07-25-2008, 05:45 AM   #22
Irish Bimmer
Drives: M Coupe
Hopefully you see this soon....
http://www.m3post.com/forums/showthread.php?t=158876
Search this Thread:
Advanced Search
zpost
