Not sure what to do... Advice is very welcomed.
05-25-2017, 03:15 PM | #1 |
Rep 6
Car E90 335i N54 2007, 80,000miles
So my cars in Limp mode and has the roughest idle imaginable. A diagnosis has thrown up all sorts of faults which has made it difficult to know where to start or to know where it will end. Would you sell in its broken state and cut your losses or put money into repairing it? Symptoms: 2A9E Inlet camshaft sensor, synchronisation 2A9F Exhaust camshaft sensor, synchronisation 2CEC: Throttle valve controller Jams briefly 2CED: Throttle valve controller Jame permanently 2CEF: Throttle valve activation 2D09: Throttle supply not correct I think these maybe separate 2DEB: power management network failure 3100: charging pressure control switch off Other notable symptoms, Engine surging Slight Oil dripping from the exhaust Oil in the engine bay (Right side this started prior to the fault initially thought cracked charge pipe) Sound of an air leak (sounds like a suction sound) Also, it won't start on the first try, normally takes a couple goes. This was a sudden fault haven't had any other issues with the car so far. |
05-25-2017, 03:43 PM | #2 |
2341
Rep 3,539
Camshaft issue easy solution, replace sensors.
Throttle body seems like it could be a shot sensor too. Oil dripping from exhaust or onto exhaust??!! If oil is dripping out of exhaust then you got yourself some major issues. Take this damn car to a good bmw shop and have them check it out. Have you checked you battery? Is it supplying the right voltage? |
05-25-2017, 03:49 PM | #3 |
126
Rep 482
+1,000,000 for above, plus check vacuum lines and charge pipe. Charge pipe could be cracked (your suction sound)
Stable:
e92is f25 N52 e83 N52 e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30) |
05-25-2017, 04:19 PM | #4 | |
964
Rep 3,854
Drives: 330i, 135i
05-29-2017, 11:31 AM | #5 | |
Rep 6
The first thing I did was change the battery (and register it) unfortunately it didn't resolve the issue. I'm replacing the charge pipe this week as I'm pretty confident this has got a leak. Although I'm starting to think there is a sensor issue also. Cam inlet or Vanos? Would this make sense? Jake |
05-29-2017, 11:33 AM | #6 | |
Rep 6
Are you referring to cam inlet sensors? Jake |
06-01-2017, 07:51 AM | #8 |
52
Rep 361
I had a mess with my (former) '06 330xi and it was the camshaft positioning sensor. I heard from many others that this part was the culprit for there problems i.e. limp mode. Replaced it and BINGO!
07-31-2017, 11:11 AM | #10 | |
494
Rep 1,416
