Need help. Car wont start. Mhd flash gone wrong.
05-24-2017, 06:45 PM | #1 |
16
Rep 116
Hey i really need some help. I put on a battery charger and pluged in mhd stock map. It then said preparrimg ecu and the wipers came on. I ripped out the cable and unplugged the battery charger. I tryed to start it amd it cranked and wont start. I pluged it in and tryed and it said no connection. Please help. My car is a 2009 bmw 335i x drive. Ran fine before.
05-24-2017, 11:53 PM | #2 |
85
Rep 207
This is somewhat common if not done properly and something I did 4 days ago. I think I may have accidently inserted my keys but forgot to turn on the car, maybe I wasn't really sure but I had the same exact symptoms with the wipers.
I simply turned off the car, took my keys out, unplugged the obd cable and started all over. Had to flash back to stock map and then do a full rewrite on my custom tune and she started right up and everything was fine.
Remember the buster
05-25-2017, 01:08 AM | #3 |
121
Rep 774
You ll be fine just replug the obd cable, and start from the begining , it may need a full flash which is 25 mins or soo depending on your car. It may start from where it left off
05-25-2017, 05:55 AM | #4 |
190
Rep 937
05-25-2017, 06:49 AM | #5 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Full flash again.
Why the heck would you unplug it???????????? What did you think was going to happen??
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
Fritzer944.50 |
05-25-2017, 07:43 AM | #6 |
772
Rep 1,418
I was thinking the same thing. Who cares if the wipers turn on, let it run it's coarse.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
Fritzer944.50 |
05-25-2017, 08:18 AM | #7 |
Maximus Decimus Meridius
1130
Rep 4,584
LoL, he ran off on the plug.. Literally..
F30 335i Melbourne Red Metallic M-Sport Package Last edited by BeastMode335i; 05-26-2017 at 06:30 AM.. |
Pavement Molestor10.50 |
05-25-2017, 09:28 AM | #8 | |
270
Rep 790
Whenever it does that, the flash will fail and frequently the ECU will go into recovery mode. When it does that, I unplug everything, turn off everything, relaunch MHD and start again. It's always worked the 2nd time so far for me at least. It will usually give an option the 2nd time to continue with the failed flash so MHD knows if you attempted a flash and failed. |
05-25-2017, 11:04 AM | #9 |
866
Rep 5,450
I have had my wipers come on also with MHD and I have had it happen flashing the trans with xhp - I think it is related to low battery voltage, but maybe not if it just works when you try again. In my case, both times I put my 70 amp charger on and it worked fine second try.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
05-25-2017, 12:13 PM | #10 |
56
Rep 318
I've only had the wipers come on once, and it was during a failed flash. I had to unplug the battery and wait a few minutes. I was then able to flash to stock and drive home, then I reflashed back to the tune. I did not need to do a full flash.
My issue was I didn't put the key in and turn the car to "ON/ACC" correctly as I've done flashes before without the keys since I have comfort access. Dumb on my part and I will always insert the key and make sure the car is "ON/ACC" before starting a flash again. |
02-12-2019, 12:57 AM | #11 |
Rep 4
MHD gone worng
hey i need help getting my car running again, the first time I tried to install MHD, my battery tender wasn't keeping up with how much energy was being used and now the battery is dead, the flash finished but everything is wrong with my car, windshield wipers are on, abs is malfunctioning, throttle is malfunctioning, etc the car revs up to 2,000 rpm over and over. I've tried reflashing with a better battery tender but the car is in the same state and the battery is still dead.
02-12-2019, 09:38 AM | #12 |
266
Rep 952
If the battery is truly shorted and won't hold 12 volts, you need to replace the battery. Charge the battery. Then test the battery voltage with the car off. If less than 12.6 volts, replace the battery.
bone stock
02-12-2019, 12:47 PM | #13 | |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Man, just do a full re-flash you interrupted the data transfer for no reason so the ECU has no idea how to run.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
