Turbo Flutter
05-24-2017, 05:18 PM | #1 |
V8 Bait
206
Rep 769
Turbo Flutter
After i accelerate, if i slightly let off the throttle, i hear air coming out of the passenger side of the engine bay, both in flutters and just air being let out. I don't believe i have a boost leak, and it started happening after i installed synapse BOV. Has anyone had this issue? Is it actual turbo flutter?
05-25-2017, 08:19 AM | #2 | |
Maximus Decimus Meridius
1130
Rep 4,584
F30 335i Melbourne Red Metallic M-Sport Package |
Antetokounmpo1551.50 |
05-25-2017, 08:21 AM | #3 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
So you hear air when you let off the throttle after you installed a BOV... got it.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
Wolf 3352340.50 BeastMode335i1130.00 Slow335xi4.00 Underground6t9316.50 ThugzZ BunnY681.50 Vincent_E9080.50 |
05-25-2017, 08:25 AM | #4 |
317
Rep 1,735
^hahaha
05-25-2017, 08:28 AM | #5 |
1130
Rep 4,584
I thought it was a troll post at first, but then again I remembered who's buying these cars now and I didn't put it past the OP lol..
Antetokounmpo1551.50 Underground6t9316.50 |
05-25-2017, 08:41 AM | #6 |
2203
Rep 3,336
Drives: X5 & E90 WTCC Widebody Racecar
Woosh sound = normal/good.
Flutter sound = compressor surge/not good. http://www.turbosmartusa.com/technic...pressor-surge/ |
05-25-2017, 08:58 AM | #7 |
V8 Bait
206
Rep 769
Ill have to post a vid when I've got time. The only trouble is the car is straight piped and it may be hard to hear it. This is happening ONLY when i slightly let off the throttle, from say, 60% or higher. My inlets are relocated by the way. Im fairly certain i do not have a boost leak, allowing the air to escape anywhere. Basically what is happening is the BOV is not opening if i only slightly let off the throttle, so the air is coming right back out the turbos. Under these conditions, there is NO BOV release. Is there a lighter spring for the synapse? Should i just replace the BOV?
05-25-2017, 08:21 PM | #8 |
V8 Bait
206
Rep 769
Update: took the spring out and i still had turbo flutter under the same conditions. About half the time, it would dump much faster, but i still would get air coming out of the turbos. At least once, the BOV didn't open and had complete flutter dump. This is very frustrating. Time to switch BOV?
05-26-2017, 06:42 AM | #9 |
140
Rep 476
Before spending any more money, personally, I would put the stock charge pipe and diverter valves back in and retest. You want to be sure it isn't compressor surge.
05-26-2017, 02:33 PM | #10 |
V8 Bait
206
Rep 769
Switched back to stock charge pipe. I still get some turbo flutter. I took off hot side intercooler piping and see some oil spray, but i don't believe that this is a simple boost leak. Will update next week with a video link. My car is so loud, you can't hear anything else, so my new exhaust will help.
09-27-2022, 08:31 PM | #11 |
V8 Bait
206
Rep 769
many years later i return to mention that the synapse BOV i had worked perfectly but in very specific cases where i only come half off the throttle i could get the charge air to shoot back out the turbo, getting flutter. probably due to the BOV spring being just a pound or two too stiff and/or the throttle not fully closing (since i was only half off-throttle) and therefore not pulling vacuum in the manifold. it was harmless.
Broke AF
