335 N54 Fuel Smell
05-24-2017, 03:54 AM | #1 |
20
Rep 76
335 N54 Fuel Smell
Hi guys,
I recently bought a 335 n54 and while I was changing the brakes I smelled fuel from the rear left wheel well. I took the liner off and found the smell coming from up top from a little hole where some wires go into and there's also some sort of sensor there. Anyone have any experience with this? Also, fun fact, car misfires/stutters at WOT at higher rpm which triggers CEL and will continue to sound like a subaru until turned off. Last edited by stelvio; 05-24-2017 at 05:46 AM.. |
05-24-2017, 04:46 AM | #2 |
20
Rep 76
UPDATE:
Removed rear bench & opened the access to fuel tank and found this: It seems the source has been found of the fuel smell. I tried wiping it but it continues to leak even after car is off. Haven't tried running car while looking at this though. Suggestions? |
05-24-2017, 08:21 AM | #3 |
Maximus Decimus Meridius
1130
Rep 4,584
F30 335i Melbourne Red Metallic M-Sport Package |
05-24-2017, 12:01 PM | #5 |
Soca Warrior
24
Rep 31
Drives: 2007 E92 335i
I had the same issue about a year ago. LPFP developed a crack in top. Had the same issues at WOT and triggering CEL. Replacing the LPFP solved the issue.
05-24-2017, 05:01 PM | #6 | |
20
Rep 76
I got new filter coming in; auto shop said that I would need to replace both buckets and would be unwise not to. Thoughts? Is he just saying that to get business or can someone confirm?
Did you change just the LPFP? P/N? |
05-24-2017, 07:05 PM | #7 |
1130
Rep 4,584
Find a new auto shop.. He's trying to sell you a LPFP as well lol..
05-25-2017, 08:38 PM | #8 |
20
Rep 76
05-25-2017, 09:22 PM | #9 |
296
Rep 2,015
This may be off topic, but did you scan for codes?
also behind left rear wheel under bumper is the Fuel Charcoal Filter for the Evap system. a crack there will do it. but you will also get a CEL on complete drive cycle after code clearing. just a thought. |
05-26-2017, 06:03 AM | #10 |
20
Rep 76
Hello, yes I scanned for codes and just got a bunch of misfires and limp mode and reduced boost, etc etc...because of my plugs [see next post]. When I removed the cap under the rear seat there was visible liquid fuel and it smelled like fuel. Hopefully I can get the filter assembly changed today in hopes that it fixes the issue.
05-26-2017, 06:07 AM | #11 |
20
Rep 76
UPDATE:
So I decided to change the sparkplugs w/ the proper Bosch ZGR6STE2 ones. When I pulled the coils I saw that the sparkplugs in place were not 12-point, but NGK PLZKAR6A-11 hex plugs [usually used on nissan sentras? LOL]...so I automatically knew I had to find my funderwear because this was going to be a fun day. For some reason I just couldn't find a socket to grab and undo these plugs so I bought a bunch [I have a stack of sockets I have to return tomorrow to Autozone] but they did have a 14mm 12-point thinwall sparkplug socket w/ rubber insert for like $6.99 or so [I removed the rubber insert otherwise it was glued to the plug]. As I was trying to remove the plug from cylinder #1 I noticed the coil couldn't be pushed completely down and when I removed the coil I saw that the sparkplug was loose. My heart dropped a little. Sure enough, one of the threads in the head seemed to be cross threaded or something. Back to autozone to see if they have helicoil for 12x1.25...they obviously didn't. Got home and ordered the Time-Serts sparkplug kit from Amazon along w/ 22mm inserts. I then went back outside and decided to inspect the other 5 plugs and change them, which went smooth. Then I got an idea: I took my drill and with an adapter I put it on the slowest speed and attempted to tighten the plug while pushing on it gently and holding the drill very still. It spun a little aimlessly but it ended up catching on the threads!! Once it caught a little I hand-tightened it accordingly [17ftlbs according to the box the plugs came in] and went out for a test drive. No more sputtering, stuttering, misfires, etc etc. Car runs smooth at WOT throughout the rev-range. I would like to take a moment now and thank Jesus for not letting this become an expense in the thousands Also, the clown who previously owned the car... |
05-26-2017, 09:18 AM | #12 | |
1130
Rep 4,584
But yes, a ton of us have experienced the cracked fuel filter situation, it's really an easy fix.. I got my fuel filter off FCP with lifetime warranty, and took me about an hour to fix.. As you can see, mine was peeing out a lot of fuel so the smell was crazy strong.. If you wipe away a bunch of that black crap and put a paper towel down while you prime the fuel system you'll most likely see the crack as I did.. But it's been fixed almost a year now and zero issues..
05-26-2017, 09:10 PM | #13 | |
20
Rep 76
That's an insane amount fuel spitting out!! I'm not that bad but definitely needs to be replaced asap. Only issue I have is that I do not have the tool to remove the ring :/ Anyone in AZ willing to lend a hand of some sorts? |
05-26-2017, 10:24 PM | #14 | |
1130
Rep 4,584
stelvio20.00 |
06-25-2017, 04:33 PM | #15 |
Rep 19
so I'm having this issue with my car. just so I'm clear the driver side has a crack in that and that's the filter? because looking around I'm having a hard time even finding a fuel filter for a e90 335,
06-27-2017, 05:19 AM | #16 |
Rep 19
ok so I found https://www.amazon.com/gp/product/B0...P9C9C3UR&psc=1
is that the only way to fix the cracked cover to buy a whole new assembly? I've tryied jb weld and some stop leak sealent but they don't seem to have enough time to set plus it would only be a temp fix |
06-27-2017, 08:03 AM | #17 | |
1007
Rep 2,108
