05-23-2017, 08:58 AM | #1 |
Not so new anymore
25
Rep 68
Audio setup for $1000 at crutchfield
Hello,
I'm newly acquiring a 2014 F22 228i with HIFI speakers in a week. I have a giftcard to crutchfield for $1k and I wanted to switch out the speakers first thing when I get the car. I've looked around the forum and made a list: AMP: JL Audio XD600/6v2 $560 Door: Focal Integration ISC 100 $150 Back: JL Audio C2-400X $140 This totals up to $850 so far. What speaker should I get for the center? Do you have any recommendation on other than these? I'm planning on installing these myself and found a good thread here and a video in bavsound website. Would I need any additional items to have these set up in my car? Thanks in advance |
05-23-2017, 10:09 AM | #2 |
4516
Rep 8,942
No center. Read the Dr Strangelove thread. Then read it again.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
nobelium2724.50 |
05-23-2017, 10:15 AM | #3 |
Not so new anymore
25
Rep 68
Ha I actually just finished reading the thread. Fantastic thread indeed. I might ditch amp as a whole and just go with speaker upgrade and dynamat xtreme. Too bad eton B100W isn't available at crutchfield. Wonder if I'll need adapter or connector for Focal ISC100.
05-23-2017, 10:28 AM | #4 | |
4516
Rep 8,942
If you have a convertible I'd recommend looking into Bavsound. Rear is much more challenging for speakers and I'd skip the amp entirely as access is a bitch.
2022 Macan S
nobelium2724.50 |
05-23-2017, 10:34 AM | #5 |
Not so new anymore
25
Rep 68
Yeah, gift card from them. I got a coupe and it looks super simple. I'd do Bavsound if it wasn't for gift card lol. Yeah, reading DrStrangeLove's thread, I'm skipping amp. Just wanted some input on speakers and any other recommendation before I order those.
05-23-2017, 10:38 AM | #6 |
35
Rep 93
Make sure to buy the ebay bmw speaker wire adapters mentioned in that thread if you dont want to splice.
nobelium2724.50 |
05-23-2017, 10:45 AM | #7 | |
Not so new anymore
25
Rep 68
http://www.ebay.com/itm/BMW-OEM-Spea...5UEnPc&vxp=mtr |
TMatt34.50 |
05-23-2017, 11:01 AM | #8 | |
4516
Rep 8,942
2022 Macan S
nobelium2724.50 |
05-23-2017, 12:46 PM | #10 |
34
Rep 73
I went with the Focal 100s. I had a professional install them (my schedule was tight) and I believe spacers are required in the doors. I detached the center speaker, definitely worth it. I used Bavsound for the subs. They are expensive but I like them.
Good luck! |
nobelium2724.50 |
05-23-2017, 12:49 PM | #11 |
120
Rep 410
You might want to change the under the seat "subs" too
nobelium2724.50 |
05-23-2017, 12:54 PM | #12 | |
4516
Rep 8,942
2022 Macan S
nobelium2724.50 |
05-23-2017, 01:34 PM | #13 | |
35
Rep 93
nobelium2724.50 |
05-23-2017, 04:02 PM | #14 | |
Not so new anymore
25
Rep 68
Yes, it says "one pair" I'll order a couple and see if that'll be enough! Is underseat sub upgrade worth it? I saw some posts that said speaker upgrade is enough. I'll read more through but I'm planning on no subs as of now. |
TMatt34.50 |
05-23-2017, 04:06 PM | #15 | ||
4516
Rep 8,942
2022 Macan S
nobelium2724.50 |
05-23-2017, 05:16 PM | #16 |
1753
Rep 2,942
OP, those JL Audio speakers will not be a good match for the Focals. They have very, very different strengths and sonic signatures, the most prominent of which is that the Focals use a metal inverted dome tweeter, while the JL Audios use a soft dome fabric tweeter.
My advice would be to put a second pair of ISC 100s in the rear. Trust me on this. That will leave you with about $120 left. Use that toward an amp install kit (Just for an amp; you don't need one with speaker wire, etc.) and sound deadening (Dynamat or equivalent). You did remember those, didn't you? Finally, budget $70 or so for the ASD Delete harness from TechnicPnP. That 600/6 won't work well at all unless you kill the ASD module. See how that sounds, then decide whether or not the underseat drivers need upgrading to you. They are by far the best speaker in the Hi-Fi setup. (And yes: DISCONNECT THAT CENTER CHANNEL!)
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
nobelium2724.50 |
05-23-2017, 05:37 PM | #17 | |
Not so new anymore
25
Rep 68
With 2 pairs of focals ($300) and dynamat ($99), I have about $600 left on the card, do you recommend anything with the left overs from crutchfield? |
05-23-2017, 05:56 PM | #18 |
Not so new anymore
25
Rep 68
Alternately, do you think Focal ISC 100 in the front and Focal PC 100 in the back would work? I saw your post that explains why PC won't work in the front, but I'm not sure if that applies to the back. What do you think Viffermike ?
05-23-2017, 06:09 PM | #19 |
4516
Rep 8,942
Remove your ash tray and order the plastic insert then mount this there, should fit. Can easily snake cables to armrest for clean install.
https://www.crutchfield.com/p_939PON....html?tp=69055 You can get Sony for $200 or FiiO same but this looks best for a car install. Crutchfield doesn't carry FiiO or I'd say mirror my X1 setup it's pretty slick.
2022 Macan S
nobelium2724.50 |
05-24-2017, 07:41 AM | #20 | |
Not so new anymore
25
Rep 68
Question about the setup: My car has enhanced bluetooth, is aux much better than EBT? I know it's generally better but worth spending extra $$$? Last edited by nobelium27; 05-24-2017 at 07:48 AM.. |
05-24-2017, 08:18 AM | #21 | ||
4516
Rep 8,942
And yes aux in is much better than BT since BT unless AptX which car does not support cannot handle lossless. It's like a lowest common denominator thing.
2022 Macan S
nobelium2724.50 |
05-24-2017, 08:49 AM | #22 | |
Not so new anymore
25
Rep 68
What do you think of Fiio X3 - https://www.amazon.com/dp/B01DT7BXZ6...ing=UTF8&psc=1 Also, Focal IFBMW-S is sold for ~$500 at crutchfield. It comes as plug and play and has tweeter (which I don't know if I can use it on HiFi?). I saw this review - http://www.2addicts.com/forums/showthread.php?t=1102486 - but I wonder if it's really worth $350 more. Last edited by nobelium27; 05-24-2017 at 08:56 AM.. |
