ac issue, driver side warm, passenger side kind of cool???
05-20-2017, 05:17 PM | #1 |
Rep 67
As stated in title, my ac isn't working 100% driver side is blowing ambient temperature, and passenger side is only some what cool, still not cool enough, even on max cool (90's+ this week). and yes dumby dial is set on cool. Read up on some forum, all they did was have a recharge and all was good, somebody told somebody try bleeding the coolant system???
05-20-2017, 06:45 PM | #2 |
58
Rep 665
That's usually a symptom of low refrigerant. If you have a slow leak, an inexpensive ($25-35) recharge kit with leak stop from Walmart or your local auto parts store may be all you need.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
05-21-2017, 04:50 AM | #3 |
187
Rep 589
Yes, typically happens from low refrigerant. The evaporator is on the passenger side of the car so the air stays colder over there but warms up by the time it makes it out the driver's side.
Evaporator leaks are fairly common on the E90. They're usually slow enough you can just get it recharged and not have a problem. I'd recommend not doing it yourself with the DIY kits, if possible. Since it's actually blowing warm it's probably lost a decent amount of refrigerant, and it's really hard to refill yourself due to the variable-displacement compressor that the E90 has. I've found that the pressure readings don't seem to behave the same way as a normal compressor, so it can be really hard to do it without overfilling it. |
05-21-2017, 10:12 PM | #4 |
18
Rep 216
not to hijack the post. I have always think that my ac is not cold enough, although it is not blowing warm air. At max settings, its blowing 60F. Is that normal? I research and see that ppl say it should be around 40-50F.
I am also deciding on using those recharge kit or not as I read a lot of mixed reviews....... |
05-27-2017, 10:07 AM | #5 |
Rep 60
i've had this issue for 2 years or so, just use a recharge kit, should last you through the summer. the climate control system in general in these cars is crap, even when it's working properly i can hardly even feel the air hitting my face on full blast.
'09 E92 SGM/ 6MT/ FBO/ JB4 + MHD BEF/ Dinan S2/ Fuel-it Stage 2
05-30-2017, 06:20 PM | #6 |
Rep 67
I ended up doing just that, I was going to take it to my friend at sears auto center, I had some left over ac pro, and gave it a shot, and it has worked the last week.
05-30-2017, 06:21 PM | #7 | |
Rep 67
05-30-2017, 06:52 PM | #8 |
18
Rep 216
05-31-2017, 01:05 PM | #9 |
Rep 67
05-31-2017, 04:18 PM | #10 |
18
Rep 216
05-31-2017, 05:45 PM | #11 |
22
Rep 118
Same thing happened to me. Bought a $30 kit and did a recharge. Didn't have any problems at all and air blows 42 degrees. There are a couple how-to videos on doing this but it's pretty simple. Access is easy. I charge once a year and it lasts through until next season. Better than the $2500 to pull the dash and fix the leak.
05-31-2017, 06:29 PM | #12 | |
18
Rep 216
06-03-2017, 09:07 PM | #13 | |
18
Rep 216
