Struggling to resolve an E90 335i In limp mode!!! (see below)
05-20-2017, 01:03 PM | #1 |
Rep 6
Driving home and suddenly my Car went into limp mode, DSC faults came up also and the car was really rough on Idle (see video).
I pulled up the following codes, 2CEC: Throttle valve controller Jams briefly 2CED: Throttle valve controller Jame permanently 2CEF: Throttle valve activation 2D09: Throttle supply not correct 3100: charging pressure control switch off (I think this may be separate) Other notable symptoms, Engine surging Slight Oil dripping from the exhaust Oil in the engine bay (This started prior to the fault) My initial thoughts were to take off the throttle body and clean it and try to trace the oil leak which I feel maybe a cracked pipe. does this sound like a good place to start and has anyone had a similar problem? Jake Car E90 335i N54 2007, 80,000miles Video: |
05-20-2017, 01:58 PM | #3 |
Rep 6
Tags |
limp mode, n54 335i, oil leak, rough idle, throttle actuators |
