Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Will a 18.8 Style 189 wheel fit a stock rear tire?
      05-13-2017, 03:40 PM   #1
cvsnowboarder
cvsnowboarder
12
Drives: 2009 335i E93 Convertible
Hi, I have a 2009 e93 335i . I have the style 189 wheels.All 4 wheels are 18.8 square set up wheels but not tires.
Will a 255/35/18 stock rear tire fit on that 18.8 wheel? If I use an 18mm spacer in the rear will it rub ? Thanks
Female driven ! Black Sapphire Metallic 2009 335i e93 Conv., Style 189 Wheels,Continental DWS,MHD Flash Stage 1 93 oct., aFe POWER Magnum FORCE Stage-2 Pro 5R Cold Air Intake System,Bilstein B8 Sport shocks,H&R Sport Springs,M3 front control arms,M3 subframe and differential bushings,black kidney grille
      05-14-2017, 09:28 PM   #2
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
255 will look oversized a bit but yes it will fit, though I wouldn't recommend it. 245 is pretty square on an 8.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      05-15-2017, 08:31 PM   #3
cvsnowboarder
cvsnowboarder
12
I'm not necessarily looking for a square set up. I just want it to drive better because of the bigger rear tire size. So will it handle better ?
      05-16-2017, 06:38 AM   #4
Antetokounmpo
1552
I said square as in the sidewall will be perpendicular to the ground. A 225 on an 8 looks slightly stretched whereas a 255 looks slightly oversized. From personal experience, I would recommend 245 on an 8 at most.
