View Poll Results: Oversteer? | |||
Yes, the setup will induce oversteer | 3 | 23.08% | |
No, the effect is negligible and there should be no oversteer | 7 | 53.85% | |
No idea | 3 | 23.08% | |
Voters: 13. You may not vote on this poll |
05-12-2017, 06:00 PM | #1 |
e90noob
1588
Rep 1,862
noob question - induce oversteer?
so based on my limited knowledge, I am thinking my current setup is inducing oversteer
just wanted to run it by people who may know better so i have a 2016 328i RWD i recently got new wheels and tires i'm running 18x8.5 apex arc-8 ET45 with 245/40/18 MPS4S tires, a square setup yes, ET45 is not ideal for the F30 ... it barely clears the front brake calipers but it fits! rears are fine i am using 5mm spacers in the front just to give myself a little more breathing room with the 5mm spacers, the fronts are sitting very flush and look great i haven't gotten the rear spacers yet will be installing 12mm spacers soon so it looks like this front sits a little wider than the rear the way it's sitting right now, is my car set up to induce oversteer? is the difference too small to really make a difference?
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
06-03-2017, 03:55 PM | #2 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Bumping front track width by 5mm per side will alter the feel a bit, but it will not induce overseer. I just popped a pair of 10mm spacers on the front to check clearance for wider wheels I'm planning to run at the track in a couple weeks, and the back end still feels nicely planted.
Ahead of the curve for specF30
06-05-2017, 12:34 PM | #3 | |
e90noob
1588
Rep 1,862
i'm doing an autocross this weekend but i have swapped wheels, tires, and installed Dinan shockware since the last time i did an autocross and track event ... so i won't be able to compare directly
08-15-2017, 04:40 PM | #4 |
Premier Host for Track Events
31
Rep 167
yes, square set ups do induce oversteer. My 435i had 275 all around and it oversteered a bit. You might have to change your driving style and get used to it. Square set ups are great for saving money on tires and having great front end grip, just takes some getting used to
Edit: Just realized you are local. If you are interested in coming to the real track, check us out!
Friday, September 15th: Buttonwillow Raceway Saturday/Sunday - October 14/15 - Autoclub Speedway |
09-04-2017, 01:23 PM | #6 | |||
1604
Rep 3,940
If you run 245 in the front and 225 in the rear, it'll reduce understeer as well. (sarcasm). |
