Oil Leak?
05-12-2017, 08:35 AM | #2 |
154
Rep 342
Drives: 2008 E90 335i; 2016 F80 M3
years of crap acumulating rather than fresh oil runs from a leak.
05-12-2017, 08:48 AM | #3 |
Gateropode
329
Rep 2,848
Yes, these are leaks.
You either somebody that did a horrible job filling up and didn't clean, or the cover filler plug rubber is dead. You also appear to have a valve gover gasket leak (from the front of the engine). You may or may not have a leak at the valvetronic motor. Since you have a leak at the gasket anyway you'd need to replace the valvetronic motor gasket anyway. You may or may not have a leak at the crankshaft position sensor (the electrical wire that goes in the top-front of the engine). Could be oil coming from the filler plug, but could be the sensor leaking. A leak there will cause a variety of driveability problems as eventually it will destroy the sensor. |
05-14-2017, 01:34 AM | #4 | ||
Rep 7
