E91 dialing 911 on unlock/start
05-11-2017, 06:43 PM | #1 |
Rep 2
I have a 2011 e91 with sport/luxury packages and nav/bluetooth, 50k miles, had it since 38k, and am having a strange issue the dealer was unable to diagnose. Occasionally, once every other week or so, the car will make an SOS call when unlocked. If you catch it in 10 seconds or so (it counts down) you can cancel it with the idrive, but if you miss that window, you get to have an awkward conversation with 911. Had about 10 of those conversations so far.
The dealer (Cooper BMW in Edmond, OK) kept the car for two days and were unable to replicate. They did a system software update for $150, which didn't seem to help. I've tried everything I can to trigger it, but it seems to happen only when unlocking and starting the car, and it's very intermittent. I disassembled and put electrical tape between the contacts on the SOS switch in the headliner thinking it was close to the pano sunroof and had possibly gotten wet at some point, thought this wouldn't explain it only happening on start. Has anyone else run into this issue? Is there a SIM card somewhere I could pull out and at least keep the calls from completing? Googled and searched here and haven't seen anything. Any help appreciated. |
05-11-2017, 07:29 PM | #2 |
193
Rep 666
I thought BMW disabled SOS connectivity when their wireless carrier retired the 2G network. Your car is calling 911 directly? Not BMW Assist?
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
05-11-2017, 07:33 PM | #3 |
Is it the shoes!?
3884
Rep 5,112
05-11-2017, 08:19 PM | #4 |
Rep 2
According to the dealer, now that BMW assist is disabled, it calls 911 directly. It's not from my phone, I asked one of the 911 operators one time if the call was from my number.
On coding out the functionality, I'd probably do that if it wasn't under an extended warranty through 100k miles, don't want to do anything to jeopardize that. I get a solid blue screen on the nav that says it's Making an SOS call, and it takes a solid minute or so to create a connection, you can see GPS coordinates onscreen while it's doing it. You cannot stop this process, removing the key does nothing, you only have that first 10 seconds to stop it. I think it's doing it asynchronously, as sometimes when you get past the BMW startup screen, you are already several seconds into the process. Last edited by PuchasGracias; 05-11-2017 at 08:20 PM.. Reason: Spelling :) |
07-09-2022, 01:18 PM | #5 |
494
Rep 1,416
This is happening to me:
2011 335i xDrive - 77000 miles I haven't driven my car much in the last year (maybe 20 miles a month) and I went almost a month without unlocking the car and starting the engine when it began happening so I thought it was a battery dying issue since a weak battery can cause all sorts of electrical issues. But battery is fine.
I was hoping my local BMW Dealership would fix this but it seems the OP said they have no clue. My car is also overdue for BMW oil/brake service by 2 months. A local mechanic told me he seen this before when a BMW was over due for service and the car SOS telematics system started making random sporadic automatic calls BUT the SOS calls was to a BMW Service Department and not to 911.
StradaRedlands4941.50 |
07-11-2022, 07:15 PM | #6 |
193
Rep 666
So my 2012 M3 did this once recently, but never again. I'm laughing at my old comment from 2017!
