Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Does negative camber reduce strut clearance?
      05-08-2017, 10:38 AM   #1
b92
b92's Avatar
540
Drives: E92 335is, 6MT
I have 18x9et30 wheels (Apex ARC-8) up front and am having an inner clearance issue with my KW coilovers - I am fine at my current ride height but I went to lower it this past weekend (7-10mm) but couldn't get the wheel back on due to contact with the strut.
In order to get to the ride height I want, my plan is to swap my current 235/40 PSS tires to 225/40 PSS (which I currently have on my stock wheels). I am not sure if this will be enough to get to the ride height I wish to achieve so I am thinking of adding a 3mm spacer to be safe.
This becomes tricky because I don't really want to push my wheel farther out than it already is, so if I add a spacer then I will want to increase my camber as well. I am currently at -1.0 on both sides so I plan to pull my alignment pins for another -.4 or -.5 degrees.
Will increasing my camber affect inner clearance with the strut? If so, should I increase that 3mm spacer to a 5mm instead?
Current inner clearance:
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon.
      05-08-2017, 10:48 AM   #2
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
No. The wheel will always be the same distance from the strut since as a macpherson strut (when changing static camber, nothing else), the whole upright (strut, hub, brakes, etc.) move together. The wheel will always be the same distance from the strut no matter what the static camber is (again, we're assuming the only change is adding camber plates, no spacers or other offset wheels which will change this). Negative camber only helps clearance from the fender.
In other words, your steering inclination axis won't change relative to your wheel camber on the macpherson strut.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
Appreciate 2
b92539.50
      05-08-2017, 11:52 AM   #3
b92
b92's Avatar
540
Thank you very much for your informative reply, exactly the type of answer I was looking for.
I will move forward with the 3mm spacers to minimize the chance of any contact
      05-08-2017, 03:27 PM   #4
Banana Clipper
Jewel Runner
Banana Clipper's Avatar
331
Drives: G01///G20///I20
I literally could not fit a credit card between my tire and strut and it was fine. If you're not rubbing now you wont rub but nothing wrong with a small spacer to make sure.
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
2024 iX - Yea, she fast
      05-09-2017, 09:10 AM   #5
b92
b92's Avatar
540
There's some rubber marks on the strut so there is some rubbing going on now. When I lower the spring perch, it will make contact with the tire so I will add the 3mm spacer
      05-09-2017, 11:38 AM   #6
Digitalize
Photographer
Digitalize's Avatar
412
Drives: 320D
Tyre will flex during load, so that clearance could change. You don't want something that's rotating rubbing against your adjustable spring perch, as it could spin the adjuster.
      05-09-2017, 01:45 PM   #7
FCobra94
Guest
n/a
Drives:
All of the above is true *UNLESS* you're adding camber via longer control arms (such as the M3 arms, etc.).
      05-09-2017, 04:10 PM   #8
Antetokounmpo
1552
Correct.
      05-10-2017, 08:20 AM   #9
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Put in a spacer to push the wheel out and provide more clearance
5mm or 10mm should be sufficient
      05-10-2017, 09:40 AM   #10
b92
b92's Avatar
540
Yeah, I'm in between 3mm and 5mm. Although I could get away with it in terms of fender clearance, I don't want to push the wheel out further because it will be uneven compared to the rears.
I hate our rear fenders. I have mine rolled and am running -3.5 degrees of camber yet I'm still rubbing.
