2010 2011 BMW 5 Series Forum F10 New Pads, same vibration |
05-05-2017, 10:39 AM | #1 |
248
Rep 544
Replaced the pads yesterday with OEM pads from Turner Motorsports. After bedding in there's still the same vibration. Everything I've read on here says these rotors don't warp but all indications and a visit to my independent BMW repair shop says otherwise.
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs |
05-05-2017, 12:51 PM | #3 |
248
Rep 544
It's a pulsating type of vibration, very different from a suspension vibration.
The rotors were pretty "dirty" and they look cleaner now. Do I need to continue to bed them in? I did probably 8 or 9 aggressive stops from about 60mph.
05-05-2017, 11:10 PM | #5 |
9161
Rep 14,521
is the pulsating only when braking? if not could be the tires are out of balance or there's a bad wear on your tire causing the vibrations. my RF's in the rear had the same pulsating feeling but when i swapped in the new tires the pulsating if gone!
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
The_M6248.00 |
05-09-2017, 11:08 AM | #7 |
Rep 20
I just bought my used 2014 535d a few months ago. It had a warped front rotor.....pulsating when braking. Took it to the dealer, told them it had a warped rotor, they checked and confirmed and resurfaced the rotors and put on a new set of pads.
The_M6248.00 |
05-09-2017, 11:30 AM | #8 | |
138
Rep 598
Warped would be the disc was no longer "flat" and even throughout. You likely had uneven surface from pad deposit. |
The_M6248.00 |
05-10-2017, 12:43 AM | #9 |
9161
Rep 14,521
is this while breaking brother? also, you do have to break in the pads and rotors and if you don't do it correctly as specified could cause issues
05-10-2017, 05:37 AM | #10 | |
248
Rep 544
05-10-2017, 12:14 PM | #11 |
4509
Rep 5,375
I can't take it any longer..... Sorry...
Your vs. you're (you are) is bad enough... But one uses BRAKES to stop a moving object. The LAST thing I want is my BRAKES to BREAK!! Flame suit on.... |
05-12-2017, 07:29 AM | #12 | |
20
Rep 80
LOL Get those damn kids OFF my lawn! Op, Did you make sure it was not the lower control arms, shimmy only when braking? or all the time?
2001 530i
2004 330i 2006 X5 4.4 the beast 2014 328i 2012 535i |
05-12-2017, 09:31 AM | #13 | ||
248
Rep 544
