Oil thermostat housing temporary fix... need advice!
05-04-2017, 02:16 AM | #1 |
Rep 59
I over torqued my oil valve cap... retapped it and stripped it twice... now the housing is cracked... I'm thinking to make a block and bolt on the oil filter hoising... temporary deleting thermostat until I got another one.. will it work or not? I don't know but I'm going to find out.. wish me luck guys...
05-04-2017, 08:13 AM | #2 |
90
Rep 386
Drives: 08 535xi 11 328xi
Not trying to sound like a jerk, but if you over tightened that bolt that many times to the point of cracking the housing, you definitely should be using a torque wrench until you understand how much a bolt should be tightened. That being said, I don't think blocking that off is a good idea unless you know how the oil flows. You don't want to block the flow of oil.
05-04-2017, 08:39 AM | #3 | |
Rep 59
05-04-2017, 09:18 AM | #4 |
126
Rep 482
Park the car until you get the part. If I were you, I would get one from the wreckers. New it costs +/- 300 $. Also as mentioned above, invest in some good torque wrenches. You need them if you DIY. If you don't have $$ for tools, you have no business fixing cars, let alone owning a BMW (Indy/dealer cost much greater than DIY).
Stable:
e92is f25 N52 e83 N52 e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30) |
05-04-2017, 09:33 AM | #5 | |
Rep 59
05-04-2017, 09:36 AM | #7 |
90
Rep 386
14ftlbs seems like a reasonable torque for that bolt. if you are running stock, running without an oil cooler might be ok, if you are tuned, I wouldn't.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe |
05-04-2017, 09:47 AM | #8 |
140
Rep 476
If I were in your position I would park the car until I had the correct part installed.
I don't advise using a torque wrench when the required torque for the fastener isn't known. I subscribe to the German methodology of 'guttenenteight', and this method (knock on wood) has never failed me. |
05-04-2017, 09:50 AM | #9 |
126
Rep 482
Maybe your torque wrench is out of spec. As I said, if you would've used a wreckers yard to pick that part, you would've been in business by now at a low cost. I don't want to sound like a jerk.
Stable:
05-04-2017, 09:52 AM | #10 |
Rep 59
05-04-2017, 10:51 AM | #11 |
252
Rep 1,157
Not saying you should do this, but I always travel on my motorcycle trips with some JB weld. I have used it to stop oil leaking from a cracked crankcase from a spill, and not only did it make it back to Canada from Cali, it survived another 15000km until the bike got stolen.
I also used it to fix a cracked camshaft bearing journal on an old gs550 beater bike. That sucker lasted over 40000km. I would try to glean the crap outta that with a good chemical degreaser/solvent then get as much JB weld into that crack and clamp it as well as possible. Once set, retap the threads and be off to the races. This would be just a temporary fix!!! |
05-04-2017, 11:23 AM | #12 | |
Rep 59
