05-02-2017, 06:18 AM | #1 |
34
Rep 68
B48 330i OEM Exhaust Upgrades
Dears,
My current ride is the 2016 LCI 330i it sounds smoother and way nicer than my previous 320i and my friend's 328i (both were N20) >>> Yet I'm looking for an Exhaust Upgrade and the M-Performance cost is as high as other non OEM, What are the options and the best mod available (DP only or Rear Muffler only or Both, or even a Full Exhaust) ... what do you guys recommend. Thanks
" if everything seems under control; you're just not going Fast enough " ??
05-02-2017, 08:45 AM | #2 |
1412
Rep 3,211
Midpipe + exhaust
If your emissions are lax in Egypt and you dont care about your countrymen since they smoke a pack an hour anyway.. downpipe as well |
benjizfrankiez1.50 |
05-02-2017, 09:50 AM | #3 |
34
Rep 68
LOL Yeah, emissions are no issue here
Any suggestions, brands Thanks
05-03-2017, 12:40 AM | #5 |
34
Rep 68
Thanks,
I have been to FI website, no price listing ... the Armytrix full system Stainless Steel with all the option is really expensive it's like $3.5k
05-03-2017, 12:53 AM | #6 |
194
Rep 881
Get yourself a 340i muffler and have it fitted by a shop (or adjust it yourself). I have the same muffler (although internally modified) and the sound is pretty impressive. I'm now looking at a cat-less DP or a non-res front pipe to complete the setup. Pretty cheap solution and give roughly the same result as most aftermarket systems. Not downplaying these at all!
I would post some video but I don't have the proper equipment. I'll see if I can get some cellphone quality video once the weather clears up. |
05-03-2017, 01:42 AM | #7 | |
34
Rep 68
I will be looking at this ... if you've a sound clip or video this will be nice thanks GregD
05-14-2017, 02:43 PM | #10 | |
194
Rep 881
Next up is mid-pipe. |
05-15-2017, 10:33 AM | #11 |
537
Rep 2,825
05-15-2017, 10:52 AM | #12 |
2984
Rep 6,034
The B48 Exhaust does sound better than the N20, due likely to being in the same family as the B58, though the N55 had a decent sounding stock exhaust as well.
05-15-2017, 11:38 PM | #13 | |
537
Rep 2,825
Them, but I wouldn't say it's a good sounding engine for a company that built its reputation off inline 6's. |
05-16-2017, 03:52 AM | #14 |
Rep 26
Drives: F31 LCI 330i xDrive
I myself have a 340i muffler with 340i CAT and I think it sounds awesome on my 330i. I like it much better than the MPE for 330i. It is something I really would recommend!
Proud owner of 2017 F31 LCI 330i xDrive
05-16-2017, 05:34 AM | #15 | |
34
Rep 68
The B48 itself sounds much better than the N20, it's just needs a better exhaust ... the 340i muffler seems the best option for me to go with ...
05-16-2017, 06:21 AM | #16 | |
194
Rep 881
On the other side, you maintain the sensors and no CEL which is a huge benefit. |
05-16-2017, 06:23 AM | #17 |
194
Rep 881
DP was planned but both would be a bit too much I guess. Res delete would add drone, which is currently non existent. Keepijg the resonator combined with DP would only slightly increase sound.
05-16-2017, 09:53 AM | #18 | |
537
Rep 2,825
sound levels will be similar when cruising, but noticeably louder when you accelerate aggressively. if you want more sound with the downpipe, I suggest a new muffler. but it is best to leave your resonator alone. |
05-16-2017, 09:51 PM | #19 |
96
Rep 274
Hi folks what is the part number for the stock 340i muffler and cat? Just axle back.
Anyone in LA who has done his mod to the B48 (I.e 330i 2016/17 engine) mind meeting me some time so I can hear it in person? If you are going to a UDE or bimmerfest lmk!!
2017 F15 40i ePerformance -M Sport
05-18-2017, 04:33 AM | #20 |
Rep 26
I don't think there are any gains in power, but the sound is clearly better, deeper. And yes, it is stock cat from 340i, it just needed some welding, other than that it was a perfect fit for my car.
06-10-2017, 02:13 AM | #21 | |
Rep 6
I would want to understand how difficult it is to fit it on my 430i. I have gone to ETK, did P/N checking and graphic overlays. The fitting (except diffuser) seems to necessitate a diameter change from 65mm between front silencer to 80mm for 440i muffler. Please, can you give me information or link to parts on how you achieved this conversion ? Is connection tube really shorter ? How have you preserved (13) / (14) fixing point on 430i ?
2016 F36 430i M-Sport 8AT | Ext Carbonschwarz Metallic | Int Korallrot | Trim M Perf Carbon set | Black double slat front grill | Black Exhaust tips | replica M Perf Rear Diffuser | Rear Spoiler
BMS BJ+ | Paddle shifters | replica M-Sport pedals | Variable Steering | Adaptive M Suspension | M-Sport Brakes | H&R Black Spacers 10mm-13mm | VSC-1 exhaust flap control |
06-10-2017, 03:19 AM | #22 | |
194
Rep 881
No need to transfer the vibration rubber IMO. |
Tags |
330i, b48, exhaust 330i oem |
