Rotor/pads
05-01-2017, 05:41 PM | #1 |
40
Rep 157
Rotor/pads
I have a stock 2011 335i xdrive with 45k miles. It is my dd and no plan on tracking and modding. Charge pipe,DP and mhd will be the only thing i will be adding in the future.My rear pads need to be replace soon and probably the rotors as well. I wanted a cross drilled/slotted for looks.OEM pads/rotors are fine with me But i hated the rusted parts.
Need recommendations Should i just stay with oem rotors/pads?if so, where to buy?dealer? If Crossdrilled/slotted rotor, what brand? And pads? where to buy? Stoptech? R1? |
05-01-2017, 05:58 PM | #2 |
317
Rep 1,735
check out ECStuning for rotor/pad packages
|instagram@underground6t9| |
05-01-2017, 06:34 PM | #3 |
2191
Rep 5,008
Rockauto. Use the centric premium rotors that are painted - they'll never show rust. They are the parent company of a lot of the other rotor companies (stop tech). High quality and no BS.
Go elsewhere if you want to pay more for no more functional gain. Pricing goes as follows (high to low): Dealer Secondary parts seller (ECS, turner, etc) Supplier/warehouser (Rockauto) If you want drilled and slotted then grab the stop tech ones from rock auto. Unbeatable value. I bought centric rear rotors and pads all around for $155 shipped, iirc. |
05-01-2017, 09:11 PM | #4 | |
40
Rep 157
Is oem semi metallic or ceramic? |
05-01-2017, 09:34 PM | #5 | |
2191
Rep 5,008
OEM is semi-metallic. Ceramic would be something to consider if you wanted to decrease your brake dust. Akebono is a good ceramic manufacturer. When shopping on Rockauto stick to the "Daily Driver" or above categories so you know you're getting good quality:$ ratio. This is my opinion. Their super cheap stuff is tempting, but I've never gone that route, FYI. |
05-01-2017, 09:41 PM | #6 |
Is it the shoes!?
3884
Rep 5,112
Cross-drilled is pointless. Slotted will help wipe the pad and prevent glazing, but you tend to go through pads more quickly. It's best just to get blanks. Good brands are:
Ate Bosch Brembo Centric EBC Meyle StopTech Zimmermann GEOMET coated rotors are ideal. They make quite the difference in both aesthetics and maintenance. They won't stick to your hub. You can identify them by the matte silver coating. |
05-01-2017, 11:16 PM | #7 |
MT or bust!
170
Rep 289
Drives: 2010 E90 335i M Sport, 6MT
This is what I got from TGS and they are an excellent upgrade. Skip the HPS pads, they are way too noisy for me.
http://topgearsolutions.com/stoptech...rs-pads-lines/
2010 E90 335i M Sport, MT - BMW PE; VRSF 7in HD; RB PCV; VRSF CP; Turbosmart KPB BOV; M3 Cowl; VRSF Cerakote DPs; Carly coding; ECS Scoops; Ziza interior LEDs; Fuel-It! Bucketless; Diff lock down brace V2; MHD E60 Map from BQ; Mishimoto OCC; Fuel-It! Ethanol Sensor; Apex 18x9 ARC-8's; StopTech slotted rotors; HPS pads; ECS brake lines; MMP turbos, inlets, outlets; 034 mounts; Kumho PS31s; BimmerLife coils
05-02-2017, 02:13 AM | #8 | |
40
Rep 157
Centric high carbon alloy cryo or just regular high carbon alloy? |
05-02-2017, 11:07 AM | #9 |
Is it the shoes!?
3884
Rep 5,112
05-02-2017, 11:15 AM | #10 |
2191
Rep 5,008
05-02-2017, 12:53 PM | #14 |
They don't want you to drive a 335i - DJ Khaled
126
Rep 444
FCP Euro has Zimmerman blank rotors. Those are OE, has no corrosion and does not warp/vibrate/pulse. It's worth it to spend the extra $20 and get OE quality rotors to get the job done once and for all. Brake vibration is hella annoying. With shipping from RockAuto its a few dollars in difference from FCP. I know cuz I just bought them a few months ago. 335 rotors are HUGE. Slight imperfections in quality will be very obviously felt. Again, I know cuz I've made the mistake in the past.
As for drilles/slotted vs stock - for your case, you won't see anything other than aesthetics and decreased pad life. I'd recommend blanks. |
Outlaw 06213.50 |
05-02-2017, 03:15 PM | #15 | |
1905
Rep 6,968
Pelican has the cheapest price on Zimmerman cross drilled. However, FCP Euro has a lifetime warranty. So, make FCP price match Pelican. Akebono pads - Amazon has the best prices on Akebono pads. I'd also get the brass caliper pin sleeves from ECS Tuning, if you want better pedal feel and better wear and longevity on the pads and rotors. Totally worth it..... Sensor - Bowa |
05-02-2017, 04:17 PM | #16 |
2191
Rep 5,008
05-02-2017, 04:25 PM | #17 | |
2191
Rep 5,008
Anyway, I've almost never found any reason to stray from Rock Auto on parts like these. Also, brass guide pins can be great, but I did find them a pain when I lived in the midwest and they were exposed to salty winters. YMMV but I have to clean and lube them couple times a year. All depends where you live, I guess |
05-02-2017, 05:50 PM | #18 | ||
1905
Rep 6,968
05-02-2017, 07:30 PM | #20 |
Is it the shoes!?
3884
Rep 5,112
05-02-2017, 08:40 PM | #21 |
2191
Rep 5,008
