05-01-2017, 11:04 AM | #1 |
84
Rep 306
TPMS sensor problem
Hey, my rear valve won't seem to take any air, it was getting low then after pumping it up and seemed to drop about 4 psi straight away. I had this with another one but BMW tightened it up which works ok now. They did it on this one and said if it leaks again it's probably because I'm using non genuine wheels? But anyway if it's not taking air it sounds like it may be faulty? If so can I get a normal valve put on in the mean time as I won't be able to use my car u till I order a new one? Thanks
05-01-2017, 11:13 AM | #2 |
13347
Rep 7,484
The seal on the valve stem is a common failure item. A normal valve would be fine in the mean time. Sometimes they nut is over torqued and that too can cause problems. 8nm is the correct torque.
It has nothing to do with non genuine wheels so don't buy the BS. However, if a wheel has been poorly refurbished and there is excess paint where the valve goes them this too can make the valve fit poorly and result in a slow leak - happened with me anyway. |
05-01-2017, 11:16 AM | #3 |
84
Rep 306
Ok cool I'll go get one fitted tomorrow. Does anyone know the replacement part number for a 335i? I'll look on eBay as they are about 50 quid from bmw
05-01-2017, 11:24 AM | #6 |
84
Rep 306
Looks like there are 2 types
http://www.ebay.co.uk/itm/Genuine-bm...MAAOSw2xRYPbzl http://www.ebay.co.uk/itm/Genuine-bm...MAAOSwj85YMyqh |
05-01-2017, 11:57 AM | #7 |
13347
Rep 7,484
Good question. My local family friendly fitter wouldn't normally touch it but he managed to borrow a kit for me. The majority of tyre change places do have the tools though.
05-01-2017, 12:02 PM | #8 |
13347
Rep 7,484
The latter was correct for mine as I have continental run flats. The difference between that one and the first one was that the first one was slightly longer.. it still fit but my tyre guy said it would protrude more. We tried both and I kept the continental one. Both fit if I remember. May be give BMW a call to verify the one for you.
05-01-2017, 12:13 PM | #9 |
84
Rep 306
Yeah looking at real oem it's the latter one too
https://www.realoem.com/bmw/enUS/par...&q=36106867147 |
