ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > Z4 DIY (Do It Yourself) Articles
  TireRack
      04-29-2008, 12:40 AM   #1
Z4MMM
Drives: 2007 Z4R 3.0si, 2007 Z4MC
Cabin air filter
Where is the cabin air filter and how is it changed?
      04-29-2008, 07:25 AM   #2
veryhuman
Taiwan
Drives: 2005 Z4 2.5I
Its under the glove box, take off the panel (2-3 screws).
You'll see a metal box with some wires, instructions I had was to remove the cables connected to the metal box for better access to the filter casing beside it (I didnt disconnect the cables fearing throwing warning lights).
The filter casing is black, to open it, the bottom flap can be removed by sliding.
Take out the old filter and making note the way it came out so you know the wind direction.
Slide the new filter in, matching the wind direction, then put everything back togather.
      04-30-2008, 01:12 PM   #3
Z4MMM
Thank you very much!
      04-30-2008, 01:30 PM   #4
Hawkeye
Hawkeye's Avatar
No_Country
2070
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Why are you changing the filter on an 07?
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      09-02-2008, 11:20 PM   #5
Z4MMM
Sorry it took so long to get back! Didn't see your question till today. I had changed the cabin filters on my 325i (very easy) and on my wife's CRV (more work than necessary) and wanted to be prepared for the distant day when my Z was off warranty!
      05-27-2010, 09:13 AM   #6
Zedfor
Meinkugelschmerzen
Zedfor's Avatar
Drives: 2003 BMW Z4 3.0i, B757-200
Here is a pretty good reason.
If you don't know where you are going, any road will take you there.
ZSCCA
ZSCCA on Facebook
      07-15-2010, 10:33 PM   #7
Nhopkins1394
Accountant, 1st Class
Nhopkins1394's Avatar
Drives: 2006 Z4 3.0si Roadster, Black
Air filter
Why do roadsters have air filters?
      07-18-2010, 05:06 PM   #8
RBull
12
Drives: 2007 M Coupe
^why not?
      08-19-2010, 02:37 PM   #9
bhoch
SSGT USMC - '78 - '86
bhoch's Avatar
13
Drives: Z4 3.0si
2007 BMW Z4  [7.33]
probably due to the fact that it allows air into the cabin and also that it has a heater and an A/C unit as well.
Thanks,
Bill
2007 3.0si Roadster Black/Red, sport, Piano Black F14 Forgestar's
      08-20-2010, 10:44 AM   #10
Nhopkins1394
air filter
The comment was made "tongue-in-cheek".
I usually have my A/C blowing full blast with the top down anyway.
Just seems like an added manufacturing expense in a convertible.
      08-21-2010, 07:12 PM   #11
lstratos
Drives: Z4 3.0i
But you need to close the top in the rain or winter anyway..
      08-21-2010, 07:16 PM   #12
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
Drives: 2006 Z4MC Interlagos
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
      08-26-2010, 10:19 AM   #13
lstratos
Drives: Z4 3.0i
I'm in the process of doing mine, took some pictures as well and will post them.. There was like tons of leafs in my filter... have to vaccum it all out.. Wasn't as bad as the pic above but still...
      08-26-2010, 11:39 AM   #14
lstratos
Drives: Z4 3.0i
Pics are 800x600, I can lower it if necessary
Once you unscrew the 2 little screws below the glove compartment, you just pull that cover down. Once you unlatch the filter compartment, get your vaccum ready... mine was cover with leaves... pretty easy to switch out..
So my existing airflow points UP, I hope thats right, unless the last person/dealer installed it wrong..
      08-26-2010, 11:54 PM   #15
XMetal
XMetal's Avatar
1097
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Thanks for posting the pictures! I'll come in handy one of these days.
      10-14-2010, 04:06 PM   #16
Nhopkins1394
Air filter in a roadster
Oh, you really don't understand.
If it's raining in Abilene (180mi away), the wife doesn't let it out of the garage.
      10-14-2010, 04:09 PM   #17
Nhopkins1394
air filter
Thanks for the images. They will come in handy.
Really should checkout my filter soon.
      11-07-2011, 10:06 PM   #18
elerner61
elerner61's Avatar
154
Drives: '07 Z4M Roadster
Swapping out this cabin filter was one pain in the a$$. 30 minutes and I had to yell the thing back together! If you don't like lying on your back under a dash stay clear.
      11-08-2011, 07:28 AM   #19
inTgr8r
inTgr8r's Avatar
2422
Drives: M2 Comp
^lol, it is a bit of a contortionist special.
1st time is a bitch, 2nd time is easier.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      03-25-2012, 12:38 PM   #20
bucko521
More of this than that!
bucko521's Avatar
29
Drives: BMW Z4 3.0i, Z3 2.5i
@LSTRATOS
Thank you for the perfect DIY. Followed your pictures and it worked as shown.
The worst part was the actual light...the cable on mine was so short...almost impossible to even lower the plastic plate even an inch or two.
Popped light out from underneath and then partially pushed through to get at the cable. then I could get at the rest. However I decided to remove the white box to get everything out of the way..making the job less challenging.
Thanks again.
'06 Z4 3.0i Jet Black/ Biege/Black
Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill
Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector
      07-29-2015, 01:00 AM   #21
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1593
Drives: 2007 Z4MC
just did this today.. lol yeah a bit of good ol swearing involved.
now i don't have to smell the PO when i turn on the airco (which is a lot)
nice clean air smell… YAY!!
of to Yas Marina circuit today… for coffee.. too hot to drive hard..
2007 EuroSpec Z4///MC - Building/Developing Z4 GT3
Powered by
Search this Thread:
Advanced Search
zpost
