F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > TPMS and what is it
Studio RSR
      04-28-2017, 07:20 AM   #1
GavMcM
GavMcM's Avatar
Drives: BMW 320i Xdrive
TPMS and what is it
Hi all, excuse the lack of knowledge.
I'm wanting to replace my OEM alloys and tyres with a set of new wheels and tyres that I've found on wheelbase.
My question is...what about the tpms...where is it located? Do the new wheels just fit on or do sensors need changed? Where are the sensors located? inside the rim and tyre?
The new wheels and tyres set i've found don't suggest anything about TPMS, is it just a straight swap...old wheels off, new wheels on? They would be getting delivered with tyres on.
Excuse my ignorance and lack of knowledge, any advice appreciated.
      04-28-2017, 07:23 AM   #2
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
Depends on the age of the car as to whether you have full TPMS (there are individual pressure transducers in the wheel valve assembly) or the earlier RDC which uses ABS sensors to detect different rotational speeds.
If you can see the actual tyre pressures in the iDrive you have TPMS and therefore will need TPMS valves for the new wheels if you don't want errors on the iDrive.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      04-28-2017, 07:27 AM   #3
GavMcM
GavMcM's Avatar
It's a 2013 car. No pressures on the I-drive. This is where i get confused. As i thought the pressures could be added with coding. Not because of the sensors themselves.
      04-28-2017, 07:34 AM   #4
xenon
xenon's Avatar
England
1397
No clearly you have to have pressure transducers (sensors) to display the pressure. It's not to do with coding - if the car has full TPMS then the pressures are displayed without any coding. (Coding can give temperature as well which isn't displayed as standard).
Anyway on a 2013 car you will just have RDC so there are no sensors so the new wheels will fit without any faff.
Ian
      04-28-2017, 07:57 AM   #5
GavMcM
GavMcM's Avatar
Thanks for that info, you've been a great help
      04-28-2017, 08:22 AM   #6
xenon
xenon's Avatar
England
1397
You're welcome.
Ian
      04-28-2017, 09:01 AM   #7
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
Are you not thinking of tyre temperature being added via coding?
Current car.M240i.
Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci.
      04-28-2017, 09:08 AM   #8
Sasquartch
606
Drives: 520i G30
My 2012 328i just has the basic ABS type TPMS
If you have ordinary rubber tyre valves then yours will be the same
My tyre fitter said the pressure sensing valves are all metal. Whether that's true I don't know
      04-28-2017, 12:08 PM   #9
Rich9600
Rich9600's Avatar
741
Drives: i4 M50
They look like this.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31)
      04-28-2017, 05:45 PM   #10
CazuaLLUK
2221
Drives: 2014 335i Black F30 M Sport
Need to retrofit these on my car!
      04-29-2017, 05:05 AM   #11
Devilot
15
Drives: F30 328i Msport
Interesting you say that, I have those, but no pressures indicated in Idrive.
So what do I have?
build April 2014
      04-29-2017, 08:02 AM   #12
philiper1
philiper1's Avatar
England
771
Drives: F21 M135i LCI
So what do I have?
build April 2014
Pressures or temperature? As the later models show both!
Current: F21 M135i Mineral Grey and few options
Previous: F30 320i XDrive, E85 2.5i, E21 323i
      04-29-2017, 08:21 AM   #13
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
You can code both pressures and temperatures on a 2013 or 2014 with TPMS.
HU_CIC or HU_NBT => RDC_SAFETY = switch to aktiv
      04-29-2017, 08:23 AM   #14
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
So what do I have?
build April 2014
You have a TPMS installed as your valve stems are metal.
      04-29-2017, 09:59 AM   #15
Rich9600
Rich9600's Avatar
741
Drives: i4 M50
So what do I have?
build April 2014
Your car was built right around the transition time. My F30 was a Jan 14 build (March 14 reg) and came with rubber stems.
I think it was the March/April 14 builds that the proper system became standard.
New cars can be coded to work with the ABS sensors... This could have been done at some pint?...
Are you the original owner? Do you know if the fitted wheels are original? Could they be a later addition?
      04-29-2017, 10:10 AM   #16
Devilot
15
I had car from new, never had any temps or pressure displayed.
Does not bother me in slightest, just wondered as other said that with metal stems I should have had pressure showing.
As you said mine must have been right at point of transition and I have hybrid of both.
f30post
