PSS rubbing with 20mm spacers
04-26-2017, 01:30 PM | #1 |
13
Rep 36
Hi guys,
I had the stock Potenzas with 162 rims on my pre-LCI E90 sized 255/35/18, and switched to the exact same size Michelin Pilot Super Sport tires. I had 20mm spacers on and they resulted in the tire edge rubbing the fender when going over dips or bumps. Attached are pictures showing what part of the tire was affected and the lip of the fender. The third picture shows the clearance with spacers removed. I removed the spacers for now, but it looks sunken and ugly. I am wondering whether stepping down to a 15mm, 12mm, or 10mm will be the largest I can go without rubbing in any condition. |
04-26-2017, 01:35 PM | #2 |
380
Rep 1,497
I ran a 255 35 on nitto nt05 with 20mm tires and had no rubbing. Even with a full car, no rubs. Sounds like the pss run wide or you can run a negative camber in the rear
04-26-2017, 01:59 PM | #4 |
13
Rep 36
Sorry, forgot to mention.
330i RWD Sport Suspension, 162 type rims. Stock everything, except the 20mm spacers, when it rubbed. Yes, these tires do seem to run wider and are very square edged on the sidewall. |
04-26-2017, 02:18 PM | #6 |
13
Rep 36
Car has less than 60k, suspension is in good shape. I don't want to roll the fender or increase negative camber, I am looking for the largest size spacer I can get away with based on anyone else that has the same setup and can confirm there is no rubbing.
04-27-2017, 12:35 PM | #10 |
187
Rep 670
When did you last have an alignment? I run the same size PSS with an 18mm spacer. Have -2.5 degrees of camber in the back. Tires wear incredibly evenly. Also have the fenders rolled, but that wasn't necessary.
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
05-15-2017, 03:09 PM | #11 |
13
Rep 36
Update for anyone else in the future who has a similar issue after switching to PSS on the stock 18" 162 rims on a sport suspension E90.
I switched from 20mm spacers (rubbing, mostly on rear right side) to 15mm spacers, and there is no rubbing any more. I tested it on speed bumps and big dips at high speeds with no rubbing sounds or marks. I am very happy now as it still looks great and has no functional issues (ideal solution). If anyone wants to buy my pair of 20mm spacers with brand new extended bolts, lmk. I might end up keeping them for my winters since the tires are narrow enough....lol |
