Are my rotors warped?
04-26-2017, 11:35 AM | #3 | |
743
Rep 1,096
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
I disagree with the shop saying warped rotors react differently to winter versus summer tires. But you said something else interesting - you don't plan on replacing rotors when you replace pads. Typically with BMWs, you replace rotors and pads simultaneously. I get about 60k miles out of a set on the front of all three of my cars (e60, e46, e90), and the pads and rotors wear down at an equal rate (roughly anyway). However, the fronts versus rears wear at completely different rates. So, perhaps you only need new front rotors. Another thing to check is tire pressure. I used to have this habit of running them up to max pressure for the tire. Doesn't matter anymore why. When my mechanic was having problems getting rid of a vibration, he insisted I drive around for a few days with BMW-recommended pressures front and rear. Of course, my mechanic was right, as the vibrations were gone. Now I am religious about setting pressures to recommendation every couple of weeks. Every time I pick up one of my cars from a tire shop, the pressures are not correct, BTW. Don't assume they properly set them for you. When I lived in the snow belt, I had a separate set of winter wheels for wife's car (the e60). At every change, fall and spring, I would carefully label the wheels as I pulled them so that I would know where to put them on next time. I would otherwise not have been able to properly rotate them. You will have to do the same when you swap between summer and winter tires, if you want to avoid cupping and other tire wear issues. hope that helps |
04-26-2017, 01:06 PM | #4 | |
87
Rep 149
I only have one set of rims, so it'll cost me money to change the tires back. Plus, it's over 60 degrees so it'll be tough to tell since the winters ride like shit above that temp.
Do I feel more of the road with the summers, and that I'm just not used to it the handling of the tires? And I did check the pressure soon after, and the tire shop completely f**ked them. Sticker on door is 35front/39rear, and the tires were all above 40. After I fixed it, I noticed that a lot of the problems went away, but I still felt a little bit of correction. As for the pads/rotors, a recent 50k service at my BMW dealer rated my brake pads at 9/10 in front and 10/10 in rear. I'm open to changing the rotors (as the front rotors are rusted), however I don't want to if they're fine and I can just clean them; plus no need to change the brakes... My car is at 47k miles, so I do need new rotors soon. Thanks a bunch. |
04-26-2017, 11:52 PM | #5 |
453
Rep 2,973
Sounds like worn bushings.
Your rotors are not warped. Maybe deposits but not warped. See this: http://stoptech.com/technical-suppor...nd-other-myths
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
04-27-2017, 10:11 AM | #6 | |
87
Rep 149
04-27-2017, 11:01 AM | #7 |
Guest
Rep n/a
Drives:
05-06-2017, 10:00 AM | #8 |
87
Rep 149
UPDATE: Figured out the problem, it was the alignment. I have an xDrive E92, and the tireshop gave me an alignment for an F30 RWD
05-07-2017, 10:24 AM | #9 | |
1073
Rep 1,957
Drives: E90 M3 LCI Jerez Black
05-10-2017, 10:38 AM | #12 |
87
Rep 149
Here's the before: View post on imgur.com I don't have a picture of the after but here's the same alignment they gave me back in 2015 that they did again (and I'm happy with) View post on imgur.com To make matters worse, when I went back to pick up my car they switched the alignment from F30 to E92, but gave me ANOTHER RWD alignment. I wasn't very happy, but once they fixed it to AWD the car handled great. I can tell they were lazy since they just assumed my 2013 3 series was an F30. Also I removed the xDrive logos on my car, so that could have thrown them off as well. Unfortunately the only two shops in my area are them and a BMW stealership. |
05-10-2017, 10:43 AM | #13 | |
Guest
Rep n/a
Drives:
Since that's the only setting that really changed from one setup to the other, you could always try doing it yourself on the next go around...it's really not that difficult. |
