F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > K2 Karcher
GetBMWParts
      04-26-2017, 01:46 AM   #1
Heavy messing
26
Drives: F30 320i M Sport
K2 Karcher
My K2 does not really foam my foam wash even though I have the foam lance. The resulting spray is more suds than thick foam. I dilute the mix, about 25-30ml in the standard 0.6 Ltr foam container....
What am I doing wrong?
      04-26-2017, 01:51 AM   #2
jang150
29
Drives: Bmw F30 320d m sport
Have you tried with a more concentrated mix? Also if it's a professional foam lance have you used the adjustment knob on the lance? If it's a standard bottle I suggest buying a professional attachment. Alternatively buy a nilfisk PW which has a metal pump!
      04-26-2017, 01:55 AM   #3
No_Country
6733
Drives: xxxx
If you are using karchers own foam lance, bin it and get an autobrite one.
http://www.autobritedirect.co.uk/ind...onnectors.html
https://www.amazon.co.uk/Lance-Karch.../dp/B00GU1YYA0
Decent deal on Amazon.
      04-26-2017, 02:03 AM   #4
DexGC
217
Drives: 435D Gran Coupe
With the autobrite stuff they recommended using warm water for the mix
      04-26-2017, 03:15 AM   #5
Craig-SM
325
Drives: BMW 320d M Sport - F30
The standard foam lance (FJ6) you get with Karchers isn't great as other have said. The FJ10 is much better or get the Autobrite snowfoam lance which is far superior but so is the price.
Your mix is very weak too at around 5% you need to up it to around 20-30%.
The density of the snowfoam varies between brands. The Autobrite snowfoam is more watery and I don't find it that effective at removing dirt regardless how warm the water is. I prefer Autofiness Snowfoam in combination with the Autobrite lance makes shaving foam thick snowfoam that clings to the car and removes much more dirt whilst using very little of the mix.
      04-26-2017, 03:36 AM   #6
wlightning
68
Drives: F30 340i EBII
Agree with Craig, OP you need a more concentrate solution. I use UF Ultimate Snow Foam and my ratio is 1:5 with warm water. Warm water definitely helps. With the Karcher foam lance you can adjust the water mixture.
      04-26-2017, 03:40 AM   #7
Heavy messing
26
Thanks lads. I'll try more mix and see if that works..
      04-26-2017, 04:27 AM   #8
Rich9600
Rich9600's Avatar
741
Drives: i4 M50
My neighbour has the K2 and the Karcher lance. It's a very poor combination, the lance is certainly the weak point.
A mate has the k2 with a similar lance to the one listed above and gets good results. Similar to me with a similar non-Karcher lance and the K4.
Basically the Karcher lance is unfortunately poor.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31)
      04-26-2017, 05:07 AM   #9
NotGotABimmer23
834
Drives: 340i touring - incoming
I have the FJ10 lance and find it spot on. 20% ratio and mix with warm water.
Also totally depends on the foam you are using.
      04-26-2017, 05:49 AM   #10
Smee
Smee's Avatar
505
Drives: BMW M4 F83
+1 for autorbrite lance best thing i bought and i have had about 4 lances in total. noting compares
about 2" in bottle then fill up warm water and cake the car
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit
      04-26-2017, 06:48 AM   #11
ronime
344
Drives: BMW X1 sDrive20i M Sport MHT
^ This.
The little yellow Karcher lance is utter shite!
Lots of detailing suppliers selling the HD foam lances so shop around.
I use a 10% solution of snow foam in warm water.
BMW X1 sDrive20i ///M Sport MHT
      04-26-2017, 06:51 AM   #12
Piggin
97
Drives: M440i
Been using the AB lance for years with their snow foam.
http://www.autobritedirect.co.uk/ind...oam-500ml.html
About 30ml & top up with warm water to 3/4 of the bottle. This gives a nice thick foam that takes the dirt away.
      04-26-2017, 07:00 AM   #13
Heavy messing
26
£40 for a nozzle and plastic bottle is a bit steep, but I guess I'll have no choice
I'm using the Gtechniq Foam wash BTW.
      04-26-2017, 07:02 AM   #14
Craig-SM
325
It is a bit eye watering but worth it.
      04-26-2017, 08:31 AM   #15
Heavy messing
26
Anybody used this product?
https://www.hygienesuppliesdirect.co...FUeZGwodTXUG_Q
      04-26-2017, 08:52 AM   #16
Rich9600
Rich9600's Avatar
741
Drives: i4 M50
Looks very similar to my own. Though, my plastic bits are black and I'm sure it's not this brand... I think most of the better ones are essentially the same item with different brand names...
      04-27-2017, 06:40 AM   #17
BimmerMad
94
Drives: 3 wheeler
Dump the Karcher. They're crap. Get a Nilkisk pressure washer and an Autobrite lance.
      04-27-2017, 07:21 AM   #18
Heavy messing
26
Ordered the Albrite lance and the Magifoam that goes with it....
f30post
