04-24-2017, 10:21 AM | #1 |
68
Rep 200
Drives: Bmw f31 335d xdrive m sport
M performance side blades fitting advice
im finally getting round to fitting the side blades.I think i read somewhere that its easiest to remove the sill covers completly and fit the blades off the car ?
anyone done this ? |
04-24-2017, 12:32 PM | #2 |
84
Rep 611
Mine are in the box awaiting push fix rivets. I looked for the 12 off plastic bolts holding on the skirt but with the car in the air it seemed easier to fit in the car.
04-24-2017, 01:38 PM | #4 |
148
Rep 1,060
Fitted mine with hydraulic jack, if you have a reasonable sized battery drill all will be fine. Had to jack front then rear to drill all holes.
G15, 840i M Sport
04-24-2017, 04:41 PM | #7 |
2524
Rep 3,863
04-25-2017, 02:41 AM | #8 |
652
Rep 926
I will be fitting these shortly, I did wonder if removing the skirts would be easier as I don't have a jack and would need an stubby angle drill which I don't have either. Does anyone have instructions for removing the side skirts please?
04-25-2017, 03:58 AM | #9 |
217
Rep 503
There are about 8 plastic bolts on the underside of the skirt, you can see them if you look under the car. Remove those then pull the skirt towards you starting at the back and working towards the front of the car
saltyamigo651.50 |
04-25-2017, 04:34 AM | #10 |
215
Rep 1,335
04-25-2017, 07:12 AM | #11 |
217
Rep 503
04-27-2017, 09:52 AM | #13 |
68
Rep 200
side blades fitted !
i had a spare hour today so i thought i wpuld have a look at fitting the side blades.
i decided to take them off to fit so i wasnt fighti g gravity and lying on my back in the drizzel. taking the sill off took all of 5 mins ! 10 plastick screws and it just pulls off starting from the back of the car. i spent anothe 10 mins cleaning the sill then wiped it with isopropyl then checked the fit and stuck them on. 17 6mm holes later and job done ! putting them back on takes anthe 5 mins per side. excuse the dirty car !! |
saltyamigo651.50 |
05-01-2017, 04:08 AM | #16 |
652
Rep 926
Thanks for the tip about removing the side sills, definitely an easier way to do it with gravity working for you rather than against you, especially if your fitting these single handed. Nice straightforward job, I ordered push fit rivets but ended up using the supplied BMW ones, they will need drilled out if I ever want to remove the sills in the future but they give a nice firm hold as they clamp the pieces together although I'm sure the push fit ones would of held the blades fine.
05-01-2017, 04:44 AM | #18 | |
68
Rep 200
and the dcal has to be fitted befor the blade as it over laps. |
05-02-2017, 01:48 AM | #21 |
84
Rep 611
Did mine last night on the car, although gravity wasn't helping I found it easy enough on the car. Saw a few guides and read the bmw one but I have no idea why they made such a meal of it!
Clean sills Drill out blades 6 and 3mm holes Offer up to car and align by pulling tight Drill a central hole and pin Drill a few more holes to align and pin Drill all remaining holes Take off blade Remove tape at one edge Offer back up and pin Pull red tape and finish off push fit rivets. Screw in self tapers to inner face Repeat for other side. |
05-16-2017, 08:05 AM | #22 |
Ü
76
Rep 469
Purchased some used blades , I have push fit riverts ready but I don't have the self tapping screws.
Any details on these, Size wise would these be ok or would I need the 5mm diva going from having to drill pre 3mm holes , washers used also ? Thanks Last edited by brtttt; 05-16-2017 at 08:42 AM.. |
