DIY: E92 Windows hitting your aluminum trim after battery disconnect
04-28-2008, 10:35 AM | #1 |
54
Rep 1,677
If you have an E92 and disconnect the battery and use your key to get into your car b/c you forgot something inside, you will notice something funky happening to your windows. Be careful shutting your door, as the window won't go down a little bit automatically to miss the aluminum trimming on the exterior. I almost shattered my window a month ago, so I figured I would share this as my SA told me the fix for it over the phone.
Once you get the battery reconnected, start by turning the car fully on. Roll the window down all the way (press and hold the button, do not let the car roll it automatically). Then do the same, making it go up. Do this 3 times and on the last time of rolling the window up, continue holding the button up for 30 seconds. Turn the car off and back on and make sure that the window now goes up and down to miss hitting your aluminum trimming. Quick window fix FTW! Just thought I would share as I almost freaked out a month ago as I couldn;t figure out how to reset it until I called my SA. Hope it helps someone!
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
04-06-2011, 10:29 AM | #2 |
18
Rep 254
if i had to go into the car when in storage and without the battery hooked up, i simply pushed on the top of the glass slightly as i closed it. The glass fit right under the trim without any dmg to the trim or window.
01-27-2014, 03:24 PM | #3 |
Beach Bum
95
Rep 210
BOOM!
Just had this issue. Thanks to this thread, it's now a non issue. Rock on!
2018 340i - lease returned
2008 335i - sold 2006 SL55 - Sold 2004 SL600 - Sold 1999 540i - Sold |
03-05-2014, 10:10 AM | #4 |
64
Rep 1,097
Drives: '11 335i E93 Alpine White
Just open the doors before you disconnect the battery, then close the doors. The windows will clear since they stay down that slight bit when you open the door. That's what I have always done. This is the best way when parked in a garage anyways.
05-10-2016, 05:22 PM | #5 |
No 55mph
1619
Rep 8,476
This forum is just a wealth of good info
Ran in to this problem today, search on the forum, & BAM there's the answer - from 2008 no less Worked like a charm
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
