04-21-2017, 05:33 AM | #1 |
44
Rep 54
Drives: M3 CS (LRG)
How to use a GoPro (hero 5 session)?
This is so incredibly frustrating it's unbelievable.
Anybody knows if there is a manual or official instructions how to use a GoPro with BMW? I have a hero5 session, I'm looking for both : 1. using gopro with M Laptimer 2. using the iDrive to control camera settings Information on the topic is ridiculously sparse and highly insufficient. About M Laptimer: I believe I can correctly connect the camera since some messages clearly state that. But camera image is not showing anywhere. I don't understand how the app works: how am I supposed to review the tracked session with video like the sample sessions? How does the video is retrieved/associated/does it need to be on phone? obviously it is in the camera's SD. Using iDrive: I found something online saying the camera sould be in "app mode" what it that? They also mention GoPro app, which I believe is now superseded by Capture. I start Capture on the phone, connect phone usb cable to car, nothing seems to happen or no particular options show up in menus. Any help is _very_ appreciated. Thanks in advance Last edited by pmilani; 04-21-2017 at 06:39 AM.. |
04-21-2017, 06:09 AM | #2 |
475
Rep 549
Drives: The Bus
Garage List 2017 Ford Focus RS [0.00]
1971 Mk3 Austin Min ... [0.00] 2013 MINI R56 GP [0.00] 2013 MINI R55 Clubvan [0.00] |
Short answer mate is it's fucked.
I have the same setup and it's very patchy. First you need to connect to the camera from the phone via wifi. Once you can see images on the phone via the Capture app that's step 1 Then connect the phone to the car via USB and open the M Laptimer app and it should all work. However, I have he GoPro connected via the front tow mount & the wifi is so week between the phone and camera that the picture keeps cutting out. In the end I purchased a Video VBOX HD2 and have not looked back!! |
pmilani43.50 |
04-26-2017, 01:44 PM | #3 |
25
Rep 36
same problem here. I cannot see gopro in menu of the M2.
I have connected camera to iphone. Iphone to car by cable (not just bluetooth). On the phone if I go into Capture App I can see live video. In the car I don't get in M Laptimer info about my Session 5 |
04-26-2017, 05:51 PM | #4 |
475
Rep 549
Drives: The Bus
BMW update the iOS app yesterday with official support for hero 5 and session. It might be worth retesting it?
pmilani43.50 |
04-28-2017, 01:14 PM | #7 | |
41
Rep 93
What is the best way to hook the go pro to the front tow hook?
2024 GLS
2016 X5 |
05-01-2017, 02:51 AM | #8 |
44
Rep 54
Drives: M3 CS (LRG)
05-01-2017, 04:08 PM | #9 |
87
Rep 105
Yep all working here in the U.K. too following the update. Very happy. When you start the laptimer it automatically starts recording. The live view has quite a bad delay however, when I tested it out just it only shows a still every few seconds. Will try tomorrow properly on a run out.
05-04-2017, 05:49 AM | #10 |
44
Rep 54
Drives: M3 CS (LRG)
So actually for 2 times already I've tried M Laptimer and no success. It shows info as if camera is connected, and even the command to shut it off works.
When I hit record the camera starts recording just as if I did it without the app: at the end there is no video associated in the M laptimer session itself. For those saying it works, have you done the same test? Also out of curiosity, how long does your camera go on battery? I had 80% charge and it shut down after about 20 minutes!? quite disappointing. |
05-09-2017, 06:37 PM | #11 |
300
Rep 357
Not sure about the GoPro5, but I recently bought the Sony HDR-AS300 to replace my (frustrating) GoPro4 Silver. I can not tell you enough how much better the AS300 is. The optical stabilizer is amazing and the battery life's definitely better than the GoPro4. Just check the comparison on YouTube. I bought the "kit" so it comes with a mini LCD remote with a wristband or you can use it on a lanyard. The AS300's only 1080P. If you want 4k, then go with the AS3000. After having 2 GoPro's and trying the Sony, I'll never go back to GoPro's.
Following are some videos I took from my last autocross. The external videos are from the GoPro4. Noticed the poor audio quality. The interior/windshield videos are from the AS300. See how much smoother they are. If they ask for a password to view, use "bmw" - off course. |
05-10-2017, 08:34 AM | #12 | |
44
Rep 54
Drives: M3 CS (LRG)
Kinda makes me confused now. I actually think the image quality of the newer Hero5 is really good tbh, and it has optical IS. It's all the mess with making it work integrated to other software that is letting me down. In your case I suppose you just hit record on the Sony and that's it. I can do as much on the gopro and it'd be fine. If it wasn't for the fact that I want to integrate the video with the M Laptimer app. Which didn't work for me even after the latest update. |
07-12-2018, 09:51 AM | #13 |
44
Rep 88
I am just wonder if the M lap timer apps only compatible to the Gopro camera? Other brand of sport camera which even also have the wifi function isn't going to work with this BMW apps?
