Tire Pressure Monitors
06-16-2005, 04:36 AM | #1 |
46
Rep 191
Tire Pressure Monitors..
When I get new wheels, are they inside the old ones. One guy says they don't have any inside each wheel, they are just sensors that watch tire spin. |
06-16-2005, 04:58 AM | #2 |
Addict
203
Rep 2,074
I believe that it's incorperated into the DSC system. It monitors the wheels spinning, if the tyre deflates, the "circumfrence" of the tyre is smaller and hence it spins faster and the DSC can read this...and warn the driver.
06-16-2005, 05:13 AM | #4 |
1307
Rep 10,185
The old systems used to be in the tires and actually cheked the pressure
The new systems use DSC to detect a change in the rolling diameter of the wheel due to a pressure loss. You must reset the system each time you change the tire pressures or change a tire. |
06-16-2005, 12:02 PM | #6 | |
96
Rep 649
Drives: 2006 BMW 325i
Does anyone know how to do this reset? Is this possibly a do it yourself thing? Is it a must go to the dealership thing? Thanks.
06-16-2005, 12:06 PM | #7 | |
29
Rep 327
09-24-2010, 05:00 AM | #8 |
Member
Rep 21
Drives: 335i, VB3s, MHD, FMIC, RBs
Not sure if I get it, why do some people talk about selling wheels with TPMS then? Sounds like it's not required anymore? Sorry, this probably a real newb question.
09-24-2010, 06:37 AM | #9 | |
I ask the questions you're afraid to ask.
44
Rep 2,489
Again, the misinformation is astounding. Can we please check the OP's location before answering? For the US (and only the US) TPMS sensors have been required in all new cars since the '07 model year. These sensors actively determine the amount of pressure in each tire and report that to the car. Pursuant to the TREAD Act, the car must alert you if the pressure falls by 25% - i.e. if your tires are at 40psi, then the car must alert you NLT 30psi. For BMW, the sensors changed with the '10 model year, so ask wwhat year the sensors came from. TPMS sensors are small pressure sensors attached to the inside of your valve stems. They are installed at the time that the tires are mounted to the wheels. If retrofitting new sensors then the tire must be (at least partially) dismounted. The rest of the world including Canada but excluding the US Either uses nothing or it uses the "indirect" method where a change in the rolling diameter alerts the driver of a problem - like Broken1 explained. The indirect method is too inaccurate as it merely senses a difference in rolling diameter. Accordingly, if all tires lost air (think long term storage) then you would not get notification. Conversely, the direct method would alert you to a loss of pressure in all tires. In addition, the indirect method reacts fairly slowly and was not considered a viable alternative following the Explorer/Firestone debacle. You will find the indirect method (called Flat Tire Monitor [FTM] by BMW) on some '06s and cars in Canada. |
09-24-2010, 07:43 AM | #10 |
Some say...
239
Rep 4,296
Drives: Fresh
I think you got that flipped, I believe all cars 07 and up have tpms in the tires and earlier models than that used the DSC.
I have exhaust and an intake... |
09-24-2010, 09:15 AM | #11 | |
Happy Camper
612
Rep 7,869
Drives: C63 AMG & 280 SL on Weekends :
Garage List 1969 Restored Merce ... [7.50]
2011 M3 Coupe TRADED [7.34] 1987 BMW 535is [1.00] Cars from the Past [6.50] The ///M3 Engine S65 [9.59] |
Car made for US or Canada Vin - CODE decoder here Tire pressure monitoring systems as you say are different in the US and or Canada. Also, if you change to winter tires with a new set of wheels you need the TPMS also in those wheels or the light on the dash will be on all the time (some people mount winter tires without the TPMS since it is quite expensive ranging from $200- to $400- for the car depending on the system, so I am told).
Cheers, Rolf-Dieter
Life will take us to some interesting places, fortunately The ///M3 will too with a many of us know this very well, now my C6.3 AMG with 487 HP does it too ---> Click here for some good stuff I found |
09-24-2010, 12:11 PM | #13 |
1566
Rep 29,202
This thread is from 2005....
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
09-24-2010, 12:43 PM | #14 |
Some say...
239
Rep 4,296
Drives: Fresh
09-24-2010, 02:14 PM | #15 |
Happy Camper
612
Rep 7,869
Cheers, Rolf-Dieter
09-24-2010, 02:19 PM | #16 |
44
Rep 2,489
09-24-2010, 03:00 PM | #17 | |
Happy Camper
612
Rep 7,869
Thanks for your post(s) Cheers Rolf-Dieter
Cheers, Rolf-Dieter
