Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > XI - 19" 8.5" 235/35/19 and 10" 235/35/19?
      04-16-2017, 08:16 PM   #1
ayyy
Lame Stance Dude
53
Drives: FBO Bagged 08 E92 335xi (V2)
I have a weird setup question I'd love to have confirmed for a pre-LCI 335xi e92. I have the opportunity to buy some wheels but the specs are worrying me:
19" 8.5 et35 front, 10 et40 rear
235/35/19 all around
The seller has a pre-LCI e90 335xi on air ride (I'm also on airliftt) and claims that the rolling diameter is within spec and "drives fine." But I've heard mixed info regarding the more you stretch, the smaller the overall diameter becomes. Especially because the recommended rear tire to go along with the 235/35 front is 265/30.
So, obvious stretching and ride quality aside, I would really love to know if this setup will be okay with my xdrive system. If not I may consider still buying the set and getting some 265/30s mounted on the rears.
Thanks in advance!
      04-17-2017, 07:18 AM   #2
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
Usually you go 235/275 with 19s to be within spec.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      04-17-2017, 03:32 PM   #3
Digitalize
Photographer
Digitalize's Avatar
412
Drives: 320D
Would look stupid having the rears stretched so much more than the fronts. Would a 265/30 not be similar rolling radius?
      04-18-2017, 07:53 AM   #4
ayyy
Lame Stance Dude
53
Agreed, but really just wanted to know if the xdrive system would be okay with it. After more research it looks like the majority believe stretching a tire does NOT reduce the rolling diameter, so in theory it would work. But I opted not to buy those wheels/tires and instead went with a new set of VMR v705s from a vendor friend. One of the last sets they'll ever make too. Specs are:
8.5 et35
9.5 et33
Planning on buying some Ventus V12 Evo2s at:
225/35/19
255/30/19
      04-19-2017, 03:20 PM   #5
AtlasM
AtlasM's Avatar
285
Drives: '11 E92 335xi 6MT
I'm an LCI xi so this may not be 100% applicable to you but my setup is:
Front: 19x8.5 +32, 235/35-19, -2.25 camber
Rear: 19x9.5 +32, 275/30-19, -2 camber
The front is fine, the rear rubbed until I rolled the fenders. I get a very slight rub on the driver's side if I go over a huge bump at highway speeds but otherwise nothing.
ayyy52.50
      04-19-2017, 08:28 PM   #6
ayyy
Lame Stance Dude
53
Thanks for the post. Yeah I hear the LCI is about 8mm "wider," so my 9.5 et33 on 255/30/19 should work just fine if you're barely rubbing at 9.5 et32 (basically et24 when you tack on the LCI 8mm) on that fatter tire.
      04-20-2017, 12:52 PM   #7
Underground6t9
Underground6t9's Avatar
317
Drives: BMW 335xi, Lexus is250
09 E92 xi specs:
235/35/19 front
275/30/19 rear
I have DWS tires
CSL reps
19x8.5 et35 with 10mm spacer (+25mm)
19x9.5 et40 with 12mm spacer (+28mm)
CB: 72.6
Rear fenders rolled
ayyy52.50
