BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - California > BC Coilovers bouncy?
      04-16-2017, 04:47 PM   #1
Eddiee07
19
Drives: 2007 BMW 328i
Just bought a set of BC br racing coilovers for my 2007 328i. Been driving around with them for about a month now when I first installed them the ride was stiff later figured out I had it on the hardest dampening setting now i am currently 6 clicks from the softest setting but the ride is super bouncy anyone have experience with these? The ride quality is just as bad as my old civic with lowering springs and stock shocks lol. Tried adjusting the dampening settings and hasn't really done much justice anything else I'm missing? I heard the preload might have something to do with the bouncy but read up that the preload is mostly for track day use?
      04-16-2017, 08:20 PM   #2
FEDE/E92
105
Drives: 2007 BMW 335i
Make sure you preload them correctly
      04-16-2017, 08:43 PM   #3
shadow191
181
Drives: 2017 Volvo XC90 R-Design
Preload won't help with ride quality. It's a linear spring so preload doesn't change spring rate or anything.
Define bouncy. Is it that you hit a bump and the car keeps moving? Or is it just stiff? How much have you adjusted the damping? The 32 adjustments don't really do much at each click so you have to adjust a lot.
Personally, I don't think BC matches the dampers well with their spring rates. I have BCs on my Infiniti and V3's on my 335. My Infiniti is bouncy too and I've just learned to live with it. Swapped out the springs already which helped some but not entirely and I'm not going to the trouble of having custom revalved shocks for budget coilovers.
      04-17-2017, 12:25 AM   #4
FEDE/E92
105
Preload to an extent affect ride quality Sag o the vechile. But if it's really bouncy spring rate is right. What spring rate on your set up
      04-17-2017, 01:47 PM   #5
Banana Clipper
Jewel Runner
Banana Clipper's Avatar
331
Drives: G01///G20///I20
One thing we've learned with the YCW's is to replace the upper and lower mounts/bushings (PN Monroe 907984 & 907985).
Check out this video:
NOT my video
Here is the thread in case you want to scan over it for useful bits that may apply to your situation:
http://www.e90post.com/forums/showthread.php?t=1368198
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
2024 iX - Yea, she fast
