04-16-2017, 12:53 PM | #1 |
111
Rep 624
Msport brakes
Hi all,
Not sure what they are officially called, but the 'covers' that go over the hubs.. The parts that you don't get on lesser models I believe. Anyway, whatever they're called - has anyone had theirs go a bit 'dull' almost like they're in need of a good scrub up? And if so, what's best to use on these? Cheers Garry 👍 |
04-16-2017, 01:03 PM | #2 |
10995
Rep 32,881
Yes the disc hats all go like that, aluminium doesn't rust but it does corrode. No cleaners or metal polish will work so you'd need to try a wire brush or emery cloth and some elbow grease.
04-16-2017, 01:15 PM | #3 |
6659
Rep 15,858
I've got the composite discs on my 5-series.
When I swap wheel sets, I use a wire brush to get the worst off. Then use T-cut on a scouring pad to give a degree of polish and shine to the alloy hat. Not a perfect solution, but improves the look between wheel changes. |
