M2 Technical Topics > Suspension | Brakes | Chassis > Loud metal on metal noise when turning left
      04-15-2017, 11:47 PM   #1
MRufo
36
Drives: M2
I'll try to make this short. When turning fairly hard to the left the right rear is making a loud noise that sounds like the dust shield hitting the rotor. I had the wheels rebalanced after a track day and did a through inspection while the wheel was off and found nothing. It sounds like a rock is stuck and it is rubbing under lateral load. It started during a track day and it's now driving me crazy. I'm running Pagid pads and now I'm wondering if they are shuddering.
I bent the shield back away from the rotor but no luck.
I'm thinking I'll change out the pads and retest since I'm running out of ideas.
Feedback? Help?
Also, I only hear it if I'm cornering fairly hard. For example, going 35 or 40 mph on a 20 mph corner.
      04-16-2017, 08:30 AM   #2
J.M
J.M's Avatar
Netherlands
263
Drives: '17 M2 DCT BSM
2017 BMW M2  [0.00]
vide "soda can crunch noise".
Check out my M2 YouTube channel: The HyperCar Collective
      04-16-2017, 10:07 AM   #3
MRufo
36
Drives: M2
No. It's a different noise. I've had that too!
      04-16-2017, 02:31 PM   #4
pruettfan
1622
Drives: 2017 M2, LBB, DCT, Exec
The diff can make some sounds when the clutch engages back there so its possible that is the issue but I would have the dealership take a look at it to be on the safe side.
      04-16-2017, 03:07 PM   #5
MRufo
36
Drives: M2
It definitely not the diff. I'm going to swap the stock pads back in and see what happens. If it's still there I'll be visiting the dealership.
I can't figure out why it only happens when the right side is hard loaded?!
It's a clack clack clack not a solid screech.
Its loud though. Was out for a drive with my wife last night on a curvy country road and she said "what the hell is that?"
      05-26-2017, 04:13 PM   #6
MRufo
36
Drives: M2
Big rock was jammed behind brake shield. I couldn't get it out - took it in and I got the new shields too.
m2
