BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY Info: E92/3 Black & Silver Carbon Fiber Roundel Replacement
      04-27-2008, 11:53 AM   #1
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
I received the new carbon fiber roundels package from Ada (adamaster) by Express Mail from Taiwan. These come with two exterior roundels (front & rear), four wheel caps, and one interior roundel for the airbag. The package comes with the newer larger sized roundels (78mm) for the rear one.
Since there is an extensive DIY on how to do the front for the E90 and it's essentially the same in the E92, I'll skip over that. However, the rear one is a little tricky so I decided to write this DIY.
1. Get one of those plastic wedges for trim removal
2. Use a thin piece of plastic card and wedge it in between the paint surface and the emblem. I used my CPR card.
3. Wedge the plastic wedge in between the plastic card and the roundel, and pry as hard as you could. You'll notice a lot of resistance because the stupid emblem has adhesive back attaching it to the trunk.
4. Once you released the old roundel, turn it over and check and see if there's any rubber grommets stuck on the emblem. If there is, remove them and replace it on the trunk opening.
5. Now comes the trick part, if you compare the stock roundel to the CF one, you'll notice that the tabs on the back of the stock emblem is indeed bigger than the CF roundel. So, you'll need to order TWO of this 51-14-1-889-489-M9, your local dealership should stock these.
6. Insert these two tiny rubber grommets to the tabs on the CF roundel, then install the roundel over the two larger black rubber grommets on your trunk.
Now you are done with installing the trunk roundels.
Pics to follow of final results.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      04-27-2008, 01:08 PM   #2
McLuVan
McLuVan's Avatar
Vietnam
304
Drives: ///M3
nice post
but wrong thread
      04-27-2008, 01:21 PM   #3
Yeahas
Drives: SG E90 328
wow i was looking for this diy all over the place..
btw wrong section dude
      05-13-2008, 07:33 PM   #4
ohten
ohten's Avatar
Drives: 2008 335i
      05-16-2008, 10:12 PM   #5
Soni
Soni's Avatar
219
Drives: Just a car
2007 335i Coupe  [9.00]
I ordered the same...but my problem is the original black rubber gormments will stop the new emblem sit flush to the trunk, because the new emblem tabs base doesn't have an indented area for the black rubber gormments to sit in...so my when I insert the tabs in all the way, I still have about 1mm space all around.
      05-17-2008, 11:24 AM   #6
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Hmm..... that's odd. Mine doesn't have any gaps after installation.
