Best suspension upgrade for the money
04-13-2017, 02:38 PM | #1 |
142
Rep 337
I have an LCI 328i sedan with stock (non-sport) suspension. I'm interested in a minor suspension improvement that makes the car feel sportier and hold the turns a bit better.
I do not... plan to track this car want anything slammed or remotely low (ideal would be stock M3 ride height) want a bumpy ride (streets in my town are horrible) I'd prefer to not spend a lot of money since this is mostly a daily driver. Honestly i should have just bought this car with the OEM sport suspension but that ship has sailed... So, any advice or recommendations? |
04-14-2017, 06:35 AM | #2 |
173
Rep 1,117
Drives: 2010 E90 328i 6MT ZSP BSM
Since you don't want anything too low and have a tight budget, I would suggest to start with a set of used Sport or M-Sport springs. On top of that, you might wish to consider a set of Koni Yellows or Koni FSD's. Brand new those might run you over your budget, if so then look for used ones.
Good luck. |
04-14-2017, 09:33 AM | #3 |
326
Rep 613
Keep saving your money.
A suspension refresh costs more than the price of shocks and/or springs. It makes no sense to touch the suspension if you're not also gonna refresh all of the mounts and other rubber around those parts. Generally, all of that will cost a minimum of $250. Then you should also account for an alignment. So, keep saving and researching until you can afford everything needed for the install |
04-14-2017, 10:42 AM | #4 |
142
Rep 337
Thanks guys. I'm not overly concerned about budget, just don't want to spend $1500 on suspension for a daily driver.
Does anyone have experience with Koni STR.T or Bilstein B12? Both seem to be reasonably priced under $1k... |
04-14-2017, 10:52 AM | #5 | |
3441
Rep 79,211
Koni STR T Orange are basically an OE upgrade. Definitely reasonable priced if you just want fresh shocks. Bilstien B12 is a great kit cause it offers all 4 shocks and lowering springs. Definitely something you want to consider if you want a slight drop and a slightly more sportier feel. As far as turn in better and stuff like that, that really falls back into your alignment (Of course shocks and springs play a role too). First thing to do is get away from stock alignment settings - they are designed and intended to understeer and provide a more conservative handling. Also, removing the strut alignment pins at the top of your front strut will allow your to increase negative camber in the front. Or if you want to do it the "ideal" method, you can do something like Dinan Camber plates or another fixed camber plate. This is getting a little beyond the scope of what most people in your position may want to do but the point is increasing the negative camber in the front of the vehicle does wonders for this platform. As well as 0 toe all around on the alignment. Most regular alignment shops won't want to go outside of stock alignment settings for liability reasons so it's best to find a race/tuner alignment shop. Anyway, sorry for the rant. There is so much that goes into the suspension and they all play an important role. |
04-14-2017, 03:14 PM | #6 |
142
Rep 337
Thanks a bunch for the tips Jeff@TopGearSolutions
So how would the Koni STRT compare to OE sport suspension? I found a kit on Euro Performance (Koni Part Number 1120-1871) for around $500. It includes blue Koni springs and advertises a 35mm front/20mm rear drop over stock. Seems ideal for me given the price and fact that I won't be tracking. As far as camber, i was planning to grab the M3 control arm + thrust arm kit from ECS since my stock thrust arm bushings are worn anyway. |
04-14-2017, 03:31 PM | #7 | |
3441
Rep 79,211
04-15-2017, 12:52 AM | #8 | |
142
Rep 337
Do you also offer the M3 thrust arm + control arms? |
04-28-2017, 09:38 PM | #9 |
1688
Rep 3,650
I'm running Koni StrT with Tein Stech springs and absolutely love the setup. I will write a review soon but I want to give it a little time first as it's only been about a week. Tein's aren't the stiffest springs but the Konis have no trouble keeping them under control and I have no bounce whatsoever. Lifetime warranty, too, regardless of the spring used with them. For the price it's a tough setup to beat.
dancing__narwhal141.50 |
05-01-2017, 10:39 AM | #10 | |
142
Rep 337
05-03-2017, 09:21 PM | #11 |
1688
Rep 3,650
I think this is more effective than sway bars would be on stock suspension, but that's just a guess. There's no noticeable body roll at all, corners really flat and the nose dive under braking is gone too. I had H&R sports for 2k miles between stock and tein so the contrast wasn't quite as noticeable as it would've been had I gone straight from stock to tein. H&R's are stiff.
05-11-2017, 06:42 AM | #13 |
1903
Rep 6,968
Honestly, I'd get the Bilstein Sport B4, if I had a 328 and going off of what you had stated. They make a non-sport B4 and a sport B4. You can get all the struts, shocks and surrounding hardware for about $600.00 total, if you plan to DIY this project.
dancing__narwhal141.50 cdgatti254.50 |
05-12-2017, 01:39 PM | #14 | |
LongDongSilver
274
Rep 706
N54 E90 6AT: 3" Pipes that go down, Thing that cools the inter, PE Mod, DCI, ST XTA, Whiteline bushings, Aodhan, and lotsa corn-juice
05-14-2017, 01:06 AM | #15 | |
1688
Rep 3,650
On 18s On my friend's 19s |
05-24-2017, 03:48 PM | #16 |
619
Rep 1,402
Bigger diameter sway bars F+R. Wheel spacers if you can fit them.
NO change in current ride height or ride quality. Will corner like you are on rails. Just did the sway bars on my commuter and handles nearly as well as my son's which has lowered bilsteins, eibachs, sway bars, 18s and spacers. Handles nearly as well with a much less harsh ride. |
05-24-2017, 11:15 PM | #17 |
2289
Rep 12,565
Drives: Z4 M, X5, GX460
If you don't want too low forget the B12's. Granted they're not slammed but sounds like you're looking for an OEM plus feel. In that case I'd look into BMW PS, Dinan/Koni, or a combo of the 2.
On my previous 135is I went BMW PS shocks + Dinan and the drop was perfect. On my current daily I went Bilstein B4 + Dinan. Your front would have been less gap since xDrive rides higher compared to rwd. |
