04-05-2017, 03:19 PM | #1 |
162
Rep 2,399
Cant connect to car.
I have purchase a package from a well known ebay seller which came with disk with all software and cable
I had to install bigger ram cards as my ram was only 2gb and E-sys premium launcher required more then 2048gb to operate So now i installed everything. I plug cable into the obd (which feels very loose until i force it in) the amber light shows on laptop and when i go to connect the e-sys to the car "connection via vin" is greyed out? Can anyone help? Seller has sent me a replacement cable too and dont work Should the light stay amber or green? |
04-05-2017, 07:42 PM | #2 |
114
Rep 243
04-05-2017, 09:27 PM | #3 |
8246
Rep 16,089
04-05-2017, 11:40 PM | #4 | |
2374
Rep 8,364
In text editor, search "javamem." You should get something like: PHP Code:
Engine should be running. Third party firewalls should be disabled. Makes mure IPV4 TCP/IP settings are set to automatic. |
04-06-2017, 08:11 AM | #5 | |
162
Rep 2,399
Is it supposed to go green? In windows xp how do i find out whether its actually connected ok? |
04-06-2017, 11:47 AM | #6 |
51
Rep 341
Check the fuse for the OBD port. It's located on your FEM. I had mine blow and I was freaking out that I might have bricked my car.
04-06-2017, 01:25 PM | #7 |
172
Rep 740
Did you change any settings in the network interface? You should be getting a 169.x.x.x address (169 address usually means no dhcp obtained address and this is normal.).
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
04-06-2017, 04:37 PM | #8 | |
162
Rep 2,399
I deleted software on my old dell which is running xp and re installed everything but still connection via vin is greyed out. On my newer laptop connection via vin showed up Does anyone know what i can try to get it to show up on my XP laptop? |
04-07-2017, 07:47 PM | #9 | |
2374
Rep 8,364
04-10-2017, 04:24 AM | #11 | |
162
Rep 2,399
I bought the laptop from the same company some years ago which was refurbished...it had the INPA / DIS / NCS Expert all for E9X already on the laptop so if I upgrade to WIN 7-10 will I lose my programs? |
04-10-2017, 07:41 AM | #12 |
8246
Rep 16,089
An OS upgrade done correctly won't lose anything. However, I had a laptop that was originally loaded with XP, later upgraded to W7, which could not be upgraded to W10 because there were no video drivers available for it that were W10 compatible. It didn't matter, within a few months the battery would no longer take a charge, and it wasn't logical to spend money on a new battery for a computer with an obsolete OS. In any event, a computer old enough that it came with XP should be considered expendable.
04-10-2017, 03:12 PM | #13 |
2374
Rep 8,364
If you do, you can always re-install them. INPA & NCS Expert should just be installed and run in Win XP compatibility mode.
