CIC coding question
04-05-2017, 08:50 AM | #1 |
Rep 49
CIC coding question
Hi, I have looked and looked and can only seem to find part answers. My car is a fully loaded 2008 E90 330d, PDC, SatNav, Bluetooth etc. But has CCC
Now if I were to get a CIC unit/screen/emulator/usb will this all just plug in and work? (From what I researched the answer seems to be yes) But I have read in several places that things like PDC might not work if the donor car didn't have that enabled. Is this true? If so that leads to a question of what needs to be coded in to enable these? I have all the software and cable. If someone would be so kind as to point me in the right direction I would be very grateful. |
04-05-2017, 08:57 AM | #2 | |
48
Rep 260
watch the bellow vid and then you can code it yourself and make sure everything works. this is how i coded my CIC retrofit and was a lot easier than i thought |
04-05-2017, 09:03 AM | #3 | |
Rep 49
04-05-2017, 09:19 AM | #4 | |
48
Rep 260
All you are doing is taking you cars option lists and programing it to the CIC so it know what menues to activate and what modules to comunicate with. |
04-05-2017, 09:25 AM | #5 | |
Rep 49
My next task is to get the 1b file from the CIC unit and generate my FSC and get my 2017 maps on there! |
04-05-2017, 09:38 AM | #6 | |
48
Rep 260
can dig it out if you like? |
04-05-2017, 09:40 AM | #7 | |
Rep 49
Did you run an emulator on yours? |
04-05-2017, 09:46 AM | #8 | |
48
Rep 260
This is the vid for the FSC code and how i did it in regards to an emulator, yes i did. i know you can script activate now but i hear it makes map updates harder to do. also when i did my retrofit i added a rear veiw camera so i purchased an emulator that could emulate the cam module as well as you cant have a emulator for each running. |
04-05-2017, 09:50 AM | #9 | |
Rep 49
So when he connects to it to read the FSC is that reading from the CIC or the car its been put in? So will that get the VIN/1b file from the CIC and not the car is what I am asking? I just have PDC which is fine for me. I will want to upgrade my combo box at some point, but one mod at a time eh?! |
04-05-2017, 09:56 AM | #11 |
Rep 49
I know that, just in that video when he is reading the car to get the FSC I am assuming its reading it from the CIC?
So in theory I can install the CIC as normal, then plug in after, do as that video does, get my FSC then install my 2017 maps fine? |
04-05-2017, 11:00 AM | #12 |
48
Rep 260
correct, it pulls of the current FSC code from the CIC and then calculates you a life time code
04-05-2017, 11:27 AM | #13 |
Rep 49
04-06-2017, 03:31 AM | #15 |
650
Rep 2,139
Drives: 2009 e92 335i MSport DCT
where do i get the software to generate the fsc ?
When you doppelkaplung you doppel your fun.
04-06-2017, 07:18 AM | #16 |
357
Rep 1,723
Check the 'Cheap and easy FSC from 1b file' thread. Everything you need is in there.
'09 335D
04-06-2017, 10:06 AM | #18 | |
48
Rep 260
there are two configs of the wiring harness depending if you have just a TCU or a TCH & MULF. check in the boot and see if you have one bog box or one big and one little in the top right side of the boot |
04-06-2017, 10:15 AM | #19 | |
Rep 49
04-06-2017, 11:24 AM | #20 | |
48
Rep 260
you can either make a cable from scratch following the bellow DIY or just buy one form ebay (i built mine just to have a go) http://www.bimmerfest.com/forums/sho...d.php?t=723325 http://www.ebay.co.uk/itm/Retrofit-k...IAAOSw1XdUWcye i have started a thread in the coding section that has a detailed PDF on what needs to be dne on how to code the combox |
04-06-2017, 03:13 PM | #21 | |
Rep 49
