04-04-2017, 02:55 AM | #1 |
28
Rep 110
Mini owners heads up
Good morning!
Just a heads up for those on the forum who may have a new mini along side their beautiful f30! (or another model with the 18i 3cyl engine). My wife's 2015 Mini Cooper 5dr was in for its first service yesterday and we were told that there was what they called an "engine upgrade" needed. Turns out that the upper crankshaft bearings were to be replaced. They said that it was due to premature wear of them on the new 1.5 3cyl engines. If any knocking or the slightest sign of wear was detected they would automatically replace the engine. My local dealer said that they have now done approx. 100 with only a handful needing the engine replacement. No indication of mileage from the ones they have had to replace the engines. Ours has only done 6.5k in the last two years since it was purchased. Just something to look out for. If you have this engine and it has even a slight knock, get it in and checked. I know that this may not be a common engine in the F30 but I think it is a popular option in the Mini. |
04-04-2017, 03:23 AM | #2 |
8773
Rep 12,253
Used to have a mini with that engine - and daughter still has one so thanks for the heads up. Originally the issue with replacement engines affected the 2 litre in the S model. Hadn't heard of it on the 3 cylinder - some early issues with the diesel but the petrol seemed to escape.
Off to f56 forum to find out more... |
04-04-2017, 03:32 AM | #3 |
1867
Rep 13,043
Drives: BMW M340I G20
This has been an issue since birth 2014 for the 3 banger and 4 in some models.It#'s also detectable by a wafty clutch pedal action on manual cars.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
04-04-2017, 03:43 AM | #4 |
1397
Rep 8,083
WTF is an "upper" crankshaft bearing when it's at home?
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
04-04-2017, 03:48 AM | #5 |
1867
Rep 13,043
I think it's the upper shell bearing which also acts as a trust collar.
04-04-2017, 03:50 AM | #6 |
1397
Rep 8,083
So not a crankshaft bearing then
Ian
04-04-2017, 03:51 AM | #7 |
1867
Rep 13,043
04-04-2017, 03:52 AM | #8 |
1867
Rep 13,043
Yes a crank that has a thrust bearing (part of the main bearing) Not the big end.
04-04-2017, 03:58 AM | #9 |
1397
Rep 8,083
Upper part of the main bearing. Gotcha.
Ian
04-04-2017, 01:09 PM | #10 | |
344
Rep 834
It disappoints me that you have to press the clutch pedal to start the engine on many vehicles. This forces the crankshaft against a dry thrust bearing.
BMW X1 sDrive20i ///M Sport MHT
04-05-2017, 05:32 AM | #12 |
1867
Rep 13,043
No it doesn't. I only pasted it as a reference to "upper crankshaft bearing" The OP has a 3 cylinder and the recall advice, So I'm guessing there might be an issue.
