The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 335d - 41AA - load pressure sensor - PLEASE HELP!
      04-01-2017, 05:00 AM   #1
Boosting35d
Boosting35d's Avatar
42
Drives: F31 335d
Guys,
Any ideas on what to do next, car is low on power low end, it's very hesitant low end like the engine is starved of air/not breathing properly
Live diagnostics show air intake is off the scales, reading 3 times the max value when under load?!
2007 e92 335d 140k mileage - remapped, egr and dpf delete (gutted)
New map sensor
New boost temp sensor
Cleaned MAF with electrical spray
Air filter reasonably new
Forge red intercooler pipe
Smoke tested - no boot leaks
New pressure converters and bracket
New turbo change over valve/switch (small valve that switches between big small turbo
Vac lines all replaced
Car keeps coming up with 41AA error code which points to MAP sensor, yep, I have already double checked fitment
Please help!
Thanks
      01-18-2023, 05:42 AM   #2
Elpach0
Drives: M57
hi did you manage to get through , 41AA fault code solved ? thx
      01-19-2023, 03:35 AM   #3
rasa bmw
243
Drives: 640d sport/f31 330d x drive
prob maf sensor,he didnt change it he just cleaned it,no amount of cleaning is going to fix a broken one,,
      01-23-2023, 04:04 PM   #4
Elpach0
Drives: M57
already cleaned it changed it and 41AA fault still here ? could engine mount leak trigger the fault thx
      01-31-2023, 04:04 AM   #5
rasa bmw
243
i doubt it,,is the car remapped at all ?
      04-10-2024, 06:16 PM   #6
Boosting35d
42
Drives: F31 335d
I had a crap map, after remap by BW Chiptune in Hayes, the issue cleared up (they diagnosed it relatively quickly)
