F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding: Rear LED Brake Bulbs and Turn Signal Bulbs
proTUNING Freaks
      03-30-2017, 09:19 AM   #1
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
Hi
I replaced the rear brake and turn signal bulbs with LED.
Also I replaced the front turn signal bulbs with LED.
Where do I have to code those rear LED in the E-SYS?
I could code the front turn signals in E-SYS as recommended. Everything works fine for the front.
>FEM_BODY
>3061
>FRA_V_L_KALTUEBERWACHUNG
and so on.
But I could not find the coding for the rear bulbs as listed in a coding cheat sheet.
>FEM_BODY/REM
>3061
>FRA_R_L_KALTUEBERWACHUNG
Actually the "FEM_BODY/REM" .ncd is missing and not listed in E-SYS.
What is the CAFD_ID of the needed file?
However, no rear bulb warning pops up in the dashboard. (It did show up for the front turn signals before coding, but no fault message for the rear LED's. Strange...)
Is coding for the rear bulbs really needed?
Car is F31.
Thx.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
      03-30-2017, 07:13 PM   #2
fortythirtyfive
640
Drives: 435i MS
Originally Posted by oceanview View Post
Hi
>FEM_BODY
>3061
and so on.
>FEM_BODY/REM
>3061
Car is F31.
Thx.
I would presume by FEM_BODY/REM they mean one or the other (maybe even both?) I'm currently having this issue as my rear brake bulbs have started flickering even with the correct coding I have just posted a thread about it
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
      03-31-2017, 09:14 AM   #3
oceanview
oceanview's Avatar
Switzerland
207
Thanks producerlawson I found the rear bulb coding in REM as you mentioned!
I will now look into the different options in REM.
Possibly I need to code for the Brake Light
BL_L
BL_R
and for the turn signal
FRA_L
FRA_R
f30post
