E90 tire suggestions
03-28-2017, 12:14 PM | #1 |
Rep 53
Hey guys,
I'm pretty new to the tire game so any help would be appreciated! I have a 2011 E90 335i and plan on upgrading to some 19" PSS summer tires from the stock run flats. Anybody have size suggestions on stock sport suspension with a staggered stance?
SG 335i E90
03-28-2017, 12:24 PM | #2 | |
232
Rep 649
Drives: F80
https://www.tirerack.com/tires/tires...Pilot+Sport+4S Sizes: 235/35/19 and 265/30/19, you will sit 3-4MM higher then stock because of the increase in sidewall height, but you will have 10MM more rubber in front and rear. If you want a cheaper option, but still a high performance summer tire, check out the Potenza pole position S-04 https://www.tirerack.com/tires/tires...+Pole+Position Same Sizes as the OEM, or you can run plus 10MM front/rear if they make it. If you want something more track / auto cross focused, check out the Bridgestone RE-71R, Great autocross tires, and insane amounts of grip for a streetable tire, will only last 1/2 as long as S-03 and 1/3 as long as PS4S https://www.tirerack.com/tires/tires...Potenza+RE-71R Run those in OEM sizes, 225/35/19 255/30/19 |
03-28-2017, 12:34 PM | #3 | |
Rep 53
Thanks for the detailed reply, I think i'm going to go with the PS4S with the size you recommended!
SG 335i E90
03-28-2017, 12:42 PM | #4 | |
Rep 53
SG 335i E90
03-28-2017, 12:52 PM | #5 | |
232
Rep 649
Drives: F80
255 is the width 30 is the aspect ratio in a percentage 19 is the rim size To find sidewall height in MM, multiply the width by the aspect ratio as a percentage 255*.3 = 76.5MM sidewall 265*.3 = 79.5MM sidewall (.11 inches higher not noticeable) 265 will fit fine on stock setup and should NOT rub, im running 265 without ANY fender modifications Here is a tirerack tech article on how to determine tire size: https://www.tirerack.com/tires/tiret...e.jsp?techid=7 |
YRN6.50 |
03-28-2017, 07:59 PM | #6 | |
Rep 53
SG 335i E90
03-29-2017, 07:03 AM | #7 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
If you still want good performance (maybe 90% of a PSS) the firestone firehawk indy 500 has gotten very good reviews and are very inexpensive. Personally I would stick with PSS/PS4S though.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
03-29-2017, 10:23 PM | #8 |
2125
Rep 3,368
Agree, great tire, but I could not believe how much less tread width they have vs PSS in same size. I went with PSS...may try the indys a later date
04-02-2017, 01:34 AM | #9 |
60
Rep 158
I just changed from RF to PS4 on my E90, you will be in for a nice surprise. I used one of the RF as my spare.
04-02-2017, 04:24 PM | #10 |
232
Rep 649
Drives: F80
Nice how do you like the PS4s? I was going to get a set, but couldnt resist picking up some r888r's how do they feel on the road, strongly considering these for my next set of tires.
04-02-2017, 04:54 PM | #11 |
1552
Rep 3,475
They're exactly the same as PSS, just 5% better in every way.
