max size spacer using stock bolts
03-24-2017, 08:46 PM | #1 |
27
Rep 221
did a quick search and didn't find any similar topics.
What is the max size spacer you can run without getting longer bolts/ i have staggered ltw and contours and square setup Kosei K1s from the e36 m3 and would like to try the michelin pss i have.. slicks on the Kosei... 41mm offsets compared to 37mm stock and having clearance issues in the fronts... a 5mm spacer should fix the issue though i have a pair of 12mm that i'd like to try. minimum 7 thread turns? |
03-25-2017, 04:52 PM | #3 |
24
Rep 195
I don't even think you can use stock bolts with 5mm spacers, so there would be no way of even using stock bolts on 12mm spacers. I would just invest in proper bolt sizes for peace of mind.
03-27-2017, 08:41 PM | #4 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
0mm spacers. Really anytime you add spacers you need new bolts. Now if you're just playing around with fitment you could get away with it but I wouldn't drive on them!
Antetokounmpo1551.50 |
03-28-2017, 05:18 AM | #5 |
Photographer
412
Rep 2,643
Can usually get away with 5mm but it depends on the length of the standard bolts. I'd do it to see if it was what was needed but then get longer bolts. But if doing that you may as well get bigger spacers too.
03-28-2017, 05:32 AM | #6 |
82
Rep 483
BMS sells longer bolts in different sizes for like $25/5 pack. Your life and car are worth much more. Spend a bit, be patient.
2011 335is Coupe MT/Space Grey/Saddle Brown/Sunroof Delete/Stripper Car
03-28-2017, 07:44 AM | #7 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
0mm.
This platform is doomed.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
