03-24-2017, 07:53 AM | #1 |
70
Rep 205
Drives: 2014 F30
JB4 Install Help
I just purchased a used JB4 from our classfied section. EWG version. '14 335i Auto.
Can someone tell me if there are more than 2 connections in the engine bay? TMAP (rainbow) and MAP (brown) correct? Also I see there are 2 identical brown MAP connectors on the harness? Which one should I use? They are both in the same area of the vehicle MAP sensor location. Also, since I have the EWG version, I do NOT need to connect the red (power) and black (ground) wire, correct? Finally, the OBDII engine side connector is missing, but there are two POSITAP style connectors back to the board side harness. Green colored wires. So...How do I know if the unit is installed correctly? How do I use it? YouTube videos show E90's using sterring wheel buttons, but I have an F30 and this doesn't seem to work. Thanks members!! Last edited by dcarp757; 03-24-2017 at 07:55 AM.. Reason: typo |
03-24-2017, 10:52 AM | #2 |
3788
Rep 5,776
I have PWG and am not real familiar with EWG, but in giving a quick look at the install guide it appears that the red and black wires are deleted. Not sure if that means yours is a older model or something different. And I would think the brown wires are for Map sensor and other for FF. The f30 JB4 is controlled by the BC button on the steering wheel stock. Refer to instructions--you hold the button and the turn signals should flash and that will let you know at least you have it hooked up.
http://www.n54tech.com/forums/showthread.php?t=18588
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
03-24-2017, 05:29 PM | #3 |
214
Rep 456
I have the same year and model as you, but my JB4 has a total of three connection points; it includes the FF connection. You most likely have the older model without it. As all the connection points, there should be two plugs. One is male and the other, female. These plug directly into your OEM plugs.
Try referring to the following PDF: http://www.burgertuning.com/instruct...4_f_series.pdf |
03-24-2017, 06:45 PM | #4 |
70
Rep 205
Drives: 2014 F30
I believe I have it connected correctly. Two total connections in the engine bay, Rainbow to TMAP and Brown to MAP. I'm not using the FF connector and of course I'm also not using the PWG connector. I have the OBDII attached as well. I had some trouble finding how to use the BC selector and run through the menu. I did find a helpful YouTube video that is worth sharing.
I have it set to MAP 2 and I can definitely feel a gain in the butt dyno. I purchased the car with the MPPK and MP Exhaust so that is my butt dyno baseline. In Sport Mode it definitely has more grunt. I have a USB cable that I haven't tried to use yet. What is the major benefit of the USB/Laptop capability? Is the Bluetooth add-on worth it? Last edited by dcarp757; 03-24-2017 at 08:50 PM.. |
03-24-2017, 11:41 PM | #5 | |
3788
Rep 5,776
03-31-2017, 09:38 AM | #6 | ||
114
Rep 469
Phone just have to buy the jb4 app. I'm favorable to the rev 3 BT kit tho it works great and is definitely worth the buy and so is the app. And if you have a cell phone holder of some type installed in your car you even doing better with it lol . |
03-31-2017, 09:48 AM | #8 |
697
Rep 2,079
The rev 3 BT kit/app is the way to go. Make your life easy, dash values, map change on the fly, user setting setup, no usb cable setup, etc..... The only thing that I have to use the steering BC button is just to open/close the exhaust flap, which I leave it open all the time.
03-31-2017, 09:52 AM | #9 | |
BimmerPost Supporting Vendor
4920
Rep 115,999
The BT APP is awesome! Mike |
03-31-2017, 04:04 PM | #10 | |
114
Rep 469
