03-23-2017, 12:26 PM | #1 |
Rep 74
Drives: BMW 330i G20 2019 Sportline
New forum member
HI,
I know this has been treated many times, so sorry if this was answered before. To restore to factory setting it is needed to go to each ECU and VO code them. But what happen if you have changed a new CAFD file at some ECU? Does the VO code also restore the original CAFDs? Thanks PS: I am new at this forum and not a fluent english speaker. Thanks for your comprehension and understanding. |
03-25-2017, 03:38 PM | #3 | |
Rep 74
When I was reading how to VO code to restore to factory settings, I wrongly understood that I had to : Read FA, Activate FA, Read SVT, left click on ECU, select CAF for SWE, select CAFD from the latest I Level list and then Code. ( I previously read the integration level from the VCM tab and used this value) I was suspecting though I have injected a CAFD that worked perfectly, ie: the car had no issues and run ok, it was not the original / factory set CAFD. Yesterday I did the VO procedure mentioned at this forum and result was ok: No issues either. It is my understanding that now I have the factory setting CAFD and of course, all the modificactions done on each ECU were restored to original values. The reason of this is I have to vist the dealer for normal maintanence service and I donīt want they see nothing that can void guarantee. Thanks for your help once again Last edited by ferbmw; 03-25-2017 at 03:44 PM.. |
03-25-2017, 03:45 PM | #4 | |
2374
Rep 8,364
Assuming you did not write FA changes to VCM, then VO procedure:
03-25-2017, 03:52 PM | #5 | |
Rep 74
Thanks again |
03-25-2017, 04:00 PM | #6 |
2374
Rep 8,364
03-25-2017, 04:28 PM | #7 |
Rep 74
