2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Acceleration rattle - around 3K RPMs
      03-19-2017, 10:04 PM   #1
jcl89
28
Drives: 2015 M235i ZF8
M235i, 8AT, 32K miles. Bought it CPO with 28404 miles two months ago. Just had the 10K miles dealership scheduled service about 3 weeks ago (oil change, scope check, vehicle inspection report).
In sport mode, I've noticed a slight rattle and ticking sound from engine/transmission when accelerating lightly with paddles. Don't really hear it at highway speeds, more noticeable on quiet roads. Shows up just around 2-3K RPMs under light acceleration blips, especially around 30-40mph in 2-4th gear. Don't really hear it in auto mode since the car usually shifts itself before 3K.
Did a ridealong with a BMW tech at a local dealership today and he said the light ticking sound is normal and is VANOS operation. Just wondering if anyone else has heard something similar.
Here's a video - driving low speed between 1st and 3rd in paddle mode, accelerating slowly (few inches down on the pedal), doing no more than 3K RPM. It's that slight rattling/buzzing sound as the revs go up.
      03-20-2017, 12:02 AM   #2
mdputnam
mdputnam's Avatar
289
Drives: 135i & M235i Convertibles
Rattle is a pretty generic term. Did the sound come from the front middle or back of the car? Could be the vanos (unlikely), heat shield, or muffler flap valve.
      03-20-2017, 01:58 AM   #3
jcl89
28
Sounded like the middle. I'm guessing it's worth checking that everything is tight under the car?
      03-20-2017, 05:15 PM   #4
mdputnam
mdputnam's Avatar
289
Yes, and don't forget inside the car.
      03-20-2017, 05:46 PM   #5
jcl89
28
When you say inside, do you mean under the hood? Is there any particular areas I should check?
      03-21-2017, 02:50 PM   #6
mdputnam
mdputnam's Avatar
289
No inside the inside of the car. Your ears can be easily fooled when in the car sometimes a sound, that you would swear is coming from outside, is really something in the interior like a rattling glove box, interior panel, or dash piece.
      03-26-2017, 07:29 PM   #7
jcl89
28
Took an 87 mile trip today and was able to reproduce the vibration sound going uphill, downhill, and straight. Seems to come on around 3000rpms, especially around 30-40mph in 3rd gear. Most noticeable under light acceleration. Sounds like it's coming from the engine or transmission since I seem to be hearing it through the Active Sound.
Guess I'll call the service advisor tomorrow and see if they can take a look.
      03-29-2017, 02:43 PM   #8
jcl89
28
Did a ridealong with a BMW tech at a local dealership. He said the ticking sound is normal and is VANOS operation.
      04-03-2017, 05:19 AM   #9
Acheron83
Acheron83's Avatar
South Africa
53
Drives: F22 M240i
2018 BMW X3 M40i  [0.00]
2016 BMW M240i  [0.00]
Sounds like a bunch of BS. Mine started doing the same thing fairly recently and certainly did not do so before.
      04-17-2017, 10:26 PM   #10
jcl89
28
So I took it to the dealer I bought it from for a 2nd opinion and they told me it was also normal. They checked it against other M235s that they had, and also verified everything was tight on the car.
      06-24-2017, 07:35 AM   #11
delvec03
90
Drives: 228i Sport/ DSB
are your tires balanced? I get a shimmy/vib at about 50 mph, but I know that's due to my tires having a resonance at that speed. too minor to drop $100 to rebalance!
      06-24-2017, 07:21 PM   #12
jcl89
28
Yep, they're balanced!
      04-03-2021, 02:19 PM   #13
Khambinho
17
Drives: 2014 335i Xdrive
Did you ever find the solution?
2addicts
