N54 Inlets - go 2' or 1.75" stock?
03-18-2017, 03:34 PM | #1 |
21
Rep 167
Ok so I want to upgrade Inlets, not planning on upgrading to larger turbos , but I seen on MMp website you can go with 2" on a 1.75" stock turbo and it works still so if you want to go bigger down the road you don't have to upgrade Inlets again.
So what do you guys think, might look at VTT also but pretty sure they are higher priced. Any ideas? |
03-18-2017, 04:33 PM | #2 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
never vtt.
Get the mmp passenger side aluminum kit. Best flowing inlets on the market. You can then just change to the 2'' silicone elbow if you ever upgrade your turbos. They sound nice too.
N54Society448.50 Rule1977194.50 |
03-18-2017, 04:41 PM | #3 |
185
Rep 1,017
If your staying oem 2" is the way to go. Running any turbo, you want as much air as possible,. This is my opinion as oem location is still along ride before the turob. The relocated ones are a nice option also.
03-18-2017, 05:04 PM | #4 |
Slow.
3782
Rep 7,151
The 2'' or `.75'' is the last elbow not the whole intake track. 2'' does not fit great on stock turbos. Might as well get the right size for the job. So it tapers down to 1.75'' instead of 2''.
03-18-2017, 05:14 PM | #6 | |
21
Rep 167
03-18-2017, 07:20 PM | #8 |
185
Rep 1,017
VTT are pushing 800+hp with there products, I would imagine it can't be that bad. Very few are doing it.
Chris@VargasTurboTech1933.00 |
03-18-2017, 10:40 PM | #9 | |
1933
Rep 1,532
Our inlets are, in our opinion, the best. No one has matched our power output, no one has matched our trap speeds, and all we want to do is push harder. Of course people talk. If you have specific questions about products, who we are as a company -anything- email me (or PM). My email address is Chris@vargasturbo.com. As for the other things -many people write things that they have no personal knowledge of/experience with, and often times those things are simply untrue. Any questions there, again, email me, we can start a dialog. We have standards that we are proud of. If you're a customer and have any issues, contact me and I will be happy to help you drive whatever issue you have to resolution. Chris |
03-19-2017, 10:48 AM | #10 |
536
Rep 2,825
be aware that the inlets only give you a real benefit on the highway. if you drive lots of city, especially living in TN with a hot climate, you will not see much of a difference in performance.
03-19-2017, 03:36 PM | #11 |
185
Rep 1,017
I'm not bias with any vendor and take what people say with a grain of salt. I was blown away with what your car is pushing and the dyno to prove it. Not that I troll on the n54 sight, cause there is so much great info and only want the best route to go when I do my n54 swap. Do it once and do it right! Seeing that I'm a deisel tech and know how harsh turbos run and what they need to be efficient. There is a reason they run 12"" filters to 4" housings. I don't care for the intake track on the 54 how it wraps around the motor.
03-19-2017, 03:38 PM | #12 |
185
Rep 1,017
That's cause turbos heat soak pulling hot air, that car would run better at night when temps are down.
03-19-2017, 04:13 PM | #13 | |
536
Rep 2,825
I'm just saying that if the OP doesnt do a good chunk of highway driving, theres really no point in installing those inlets unless he wants them purely for cosmetics. you would probably get better gains from upgrading your intercooler or literally just painting it black so it reduces heat more effectively. the general consensus is that there is absolutely no point in upgrading the intake system unless you are pushing huge turbo boost/upgraded turbos in which case the stock airbox simply becomes a bottleneck. otherwise, any BMW air intake whether it is for an NA or turbo engine will be better designed then a piece of metal with a cone filter on it. have you seen a comparison between the BMS dual cone intakes and the factory airbox? the different in temps were minimal, and that tiny improvement is offset at low speeds/sitting in traffic where the cones become completely heat soaked in traffic anyways.. on a sidenote, an air intake can give you good gains on a car with a poorly designed factory airbox, but BMW's stuff is very well designed and better then anything aftermarket (unless you have upgraded turbos, which the factory airbox does not account for) same goes for any stock BMW catback system. the design/layout/quality of the OEM piping is very good and does not offer any real restriction other then the downpipe, muffler and secondary cats (depending on which chassis and engine you have) if you do something with these parts, it will sound pretty much almost as good as a $1000 catback and flow equally well for half the price. before you guys decide you should fuck around with something so well designed, study the stock part, compare it to whatever you want to replace it with and make sure its worth wasting the money because often its not worth it (again, unless you have upgraded turbos) |
03-19-2017, 04:58 PM | #14 | |
Slow.
3782
Rep 7,151
The gains are mainly in the higher rpm ranges at wot when tuned. so 3.5-4k + basically, which is what you would expect. Inlets were proven over 2 years ago. I seriously don't understand why try and refute them. But hey if you don't want to run them go for it.
03-19-2017, 05:57 PM | #15 | |
536
Rep 2,825
I mean, theres gains in the high end, but look at the loss in low end torque and the whole mid range is literally identical.. if you literally drive above 5000RPM all day long I see how it makes sense, but otherwise I would much rather spend that money on the intercooler instead. |
03-19-2017, 07:00 PM | #16 | |
MT or bust!
170
Rep 289
Drives: 2010 E90 335i M Sport, 6MT
2010 E90 335i M Sport, MT - BMW PE; VRSF 7in HD; RB PCV; VRSF CP; Turbosmart KPB BOV; M3 Cowl; VRSF Cerakote DPs; Carly coding; ECS Scoops; Ziza interior LEDs; Fuel-It! Bucketless; Diff lock down brace V2; MHD E60 Map from BQ; Mishimoto OCC; Fuel-It! Ethanol Sensor; Apex 18x9 ARC-8's; StopTech slotted rotors; HPS pads; ECS brake lines; MMP turbos, inlets, outlets; 034 mounts; Kumho PS31s; BimmerLife coils
03-19-2017, 07:56 PM | #17 | |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
Bimmer 808170.00 |
03-19-2017, 10:04 PM | #18 |
61
Rep 174
I think I might be ok with the "frankeneffect " on tuning and hardware. It will definitely make fratricide a forgone conclusion when it comes to people who think he wrote the n54 tuning bible.
03-20-2017, 11:18 AM | #19 |
3441
Rep 79,211
Nothing wrong with VTT, in fact it's our preferred recommendation for inlets and outlets. VRSF has another good inlet option too.
As far as choosing the size, choose the right size for today. If you go bigger turbo down the road (which 99% of people say and never do), it's a quick sell in the classifieds for a used inlet, then just buy the appropriate one needed at that time. They are cheap enough anyway where in the grand scheme of costs, it's pretty trivial. |
03-21-2017, 11:27 AM | #20 | |
197
Rep 1,070
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
03-21-2017, 01:21 PM | #21 |
Sua Sponte
1299
Rep 2,850
FWIW, I've had the RB's on for a year now with zero issues. I was just very careful installing them making sure the inlet and clamp were fully seated.
jwebb335xi197.00 |
03-21-2017, 01:38 PM | #22 | |
197
Rep 1,070
JWebb335xi
